I've recently switched back to Toyota Red anti-freeze/coolant in my Tundra. I had a Toyota dealer flush the Dex-Cool that was causing problems. The Red is a concentrate (not pre-mixed), so I assume that Toyota did the proper 50/50 mix with distilled water. Is there a simple, cheap test that I can do to check the coolant for proper mix? Like a Ph litmus test or something similar?
Thanks.
Thanks.
