Shower Valve
CA
Cartridge in my parent’s shower valve is leaking.
I believe it is original to the house, so 1979 era. Trim shows Price Pfister.
I did a search and was unable to confirm the cartridge model needed, so I think we’ll need to hire a plumber to cut out the shower valve and install a new valve, cartridge and trim kit.
Does anyone have recommendations on a quality shower valve and cartridge? I have had reasonable success with Moen, but was told to be wary of their new M-PACT designs?
Thanks.
Kohler and Delta have come up most often when this subject arises.
I was never a fan of the single cartridge mode.
Hopefully, cartridges are as improved as Fumoto valves. Remember, such items were bad too in the '70's.
I just changed out the cartridge in my 2015 Moen Posi-Temp, it's a terrible design and I would not go with it again.
When I built my first house, I used American Standard fixtures everywhere. I noticed that when I went to public bathrooms the fixtures were usually American Standard. No problems with any of them in the nearly 26 years that we were there.
I have a Delta single handle shower faucet that was replaced in 1994 and is still going strong (no leaks whatsoever....knock on wood). I have had to replace the cartridge in my other shower's Moen faucet twice since a 2006 remodel.
Just installed a Moen Caldwell in a friends house in place of an old 2 handle. I thought the quality was decent and the install wasn't bad. I did convert things over to PEX so connections were easy.
I'm also a fan of the Moen plumbing supplies with the lifetime warranty. You can avoid the issues with the M-PACT cartridge design if you install the Moen commercial grade valve which uses a brass cartridge instead of the nylon plastic cartridge.
Links:
https://solutions.moen.com/Article_Library/A_Comparison_of_M-Core,_PosiTemp_and_Moentrol_Valves?
https://solutions.moen.com/Single_Handle_Shower:_M-Core_Valve
The current setup controls temperature and water volume using a single knob, but I think the water volume is fixed. It looks like I'll have to ask my parents if water volume control is a desired feature.
I have not attempted removal; I am concerned that I'll run into issues given the age.
