- Joined
- Nov 29, 2009
- Messages
- 9,750
Like once every 50k do a short 1-2000 mile run to help clean things out?
No.Like once every 50k do a short 1-2000 mile run to help clean things out?
It does not hurt anything. It does not make up for ill effects of running oil too long at another time. Fresh Oil does not repair damage of old, depleted oil. Also, oil retains its cleaning properties well past 1,000 miles. You might find some folks advocating short oil changes to chase through extremely sludgy engines in very special circumstances, where essentially you are trying to dilute recalcitrant oil. Beyond that, the idea of the occasional short oil change is wasteful or resources and not based on the properties of the oil or how oil works.I don't see it hurting anything if you periodically run the oil a little too long.
Because oil is (usually) changed much more regularly than trans fluid.so why not do the same with oil?
The only time that makes sense is if you are trying to actively get rid of something you introduced. Say engine work or hydrolock, or headgaket leak etc.Like once every 50k do a short 1-2000 mile run to help clean things out?
If you follow a reasonable OCI, your short OCI is not needed.Like once every 50k do a short 1-2000 mile run to help clean things out?
If one has the typical BITOG stash, yes
I might have to try thisDon't forget the sacrificial 1qt pour through when draining oil.![]()
People do that because a lot of transmission fluid is held in the torque converter and many torque converters don't have provisions to drain them. So a few short interval drain and refills gets most of that fluid out.People do 3 short transmission fluid intervals to try and change all the fluid (usually when the transmission has alot of miles on the original fluid.) so why not do the same with oil? It's probably not going to matter on a well maintained engine but I can see the reasoning on a car with unknown history.
Had a friend that did that. He also ran straight 40 weight. Engine didn't live any longer imo.I might have to try this
I just fill mine with carb cleaner, right up to the fill hole, then drain it and fill with new oil.If you feel the need to "clean thing out", better course of action IMHO is to use a dedicated cleaner. *cough* *cough* HPL EC *cough*.
