- Joined
- Apr 30, 2026
- Messages
- 4
Looked pretty good when I did the valve cover gasket at 390k.BUT OMG IT MAY NOT BE CLEAN INSIDE OMG
Troll city going on here. Give it up.I would say absolutely not. If an engine requires botique oils it's probably a poor design. For example a 4.0L Toyota 1GR FE will run an exceedingly long time on run of the mill oil while being flogged on.
Flame away.
Just the truth.Troll city going on here. Give it up.
So you don’t think a Tacoma that has been modified for off roading or over landing would benefit from a boutique oil in a desert climate with extreme use?Just the truth.
No.So you don’t think a Tacoma that has been modified for off roading or over landing would benefit from a boutique oil in a desert climate with extreme use?
This.You'll notice most give you some information on how much they exceed (or not) a particular spec - for example - 79% better than IVA, or 20X better than IIIH etc.
I posted an article awhile back of an XOM engineer talking about specifications for the Supercar oil. They weren't trying to just meet the spec.
"We were trying to put together an oil that would just crush all of those tests and well exceed the limits for those, "Salvesen says
I think you mean SAE grade, and your anecdotes of high BHP cars that get babied around on premium boutique oils really doesn't address the subject of how an oil that "meets the spec", particularly when it's just the basic API/ILSAC one, obviates the need for scrutiny of brand, performance...etc.On a different take - - An oil brand may have no specifications other than API grade and may actually be the "best" oil for your car. For many decades I have used Bio-based Renewable Lubricants Inc. motor oils. And I probably ran a grade or two or three lower than as specified by the engine manufacturers. All motors had 5 or 6 or 800 BHP. As far as I could demonstrate by oil analysis of various methods, compression tests and by inspection. Wear rates were minimal to none, all engines were spotless, power levels were increased as was fuel economy. There was no current MB, BMW, VW, GM, nor Ford certification. This is still my "go to" oil.
I agree with Bwalker that air filtration may be one of the most important factors and/or achieving a clean oil by changing often when needed. Clean oil by the best air filtration is probably more important than grade in many situations. If the oil stays clean, thickens minimally from oxidation and has an appropriate acid to base ratio then longer oil change intervals are possible.
Ali
Absolutely!I would say absolutely not. If an engine requires botique oils it's probably a poor design. For example a 4.0L Toyota 1GR FE will run an exceedingly long time on run of the mill oil while being flogged on.
Flame away.
Specs maybe. But real life is different.Absolutely!
Both conventional and full synth. oils cover the same specs. So, why not choose the cheapest oil? People who buy synthetics are wasting money.
However, some oils are offered only as full synthetic 0W-20, 0W-30, 0W-40, 5W-40 and a handful more.
So, choose your poison!![]()
I personally don’t want stuck rings and nasty ring grooves so from that perspective no, all oils hitting a spec are not the same. We have seen it on this site where an engine running on “top tier” full synthetic starts shedding carbon gunk when exposed to HPL or Valvoline Restore and Protect.Absolutely!
AMSOIL SS is a great example of "exceeding the specs." See here.I'm not sure what folks expect by " exceeding the specs" .
Yes but you cannot extrapolate your experience with a bomb proof, old school port injected, naturally aspirated Toyota engine (I'm guessing 5VZ-FE here). Lots of old engines went 300k+ on Chevron Supreme conventional too. The issue is when people like you with an experience in a great engine make blanket statements and try to apply that to new, turbo GDI engines. That worked for you, in your engine, and with your driving style and in your climate.I just replaced my 4runner with over 400k on it. It was in my family since 30k, and mine since 170k. It got chevron, super tech, or Quaker state every 5k miles. Sometimes high mileage formula. I was even using conventional in it until that wasn't available, then it was synthetic blend. I'm in the camp that says clean oil is what counts. For a high performance engine or extreme conditions I might be more picky.
Whether oil choice makes a difference in these more complicated, higher stress and often lower quality engines is just as questionable. Supposition and assumptions abound.Yes but you cannot extrapolate your experience with a bomb proof, old school port injected, naturally aspirated Toyota engine (I'm guessing 5VZ-FE here). Lots of old engines went 300k+ on Chevron Supreme conventional too. The issue is when people like you with an experience in a great engine make blanket statements and try to apply that to new, turbo GDI engines. That worked for you, in your engine, and with your driving style and in your climate.
I don't think so. I think it's clear higher quality oils do better in these newer, higher power/displacement engines. Proof abounds here. So many people with oil burning now.Whether oil choice makes a difference in these more complicated, higher stress and often lower quality engines is just as questionable. Supposition and assumptions abound.
"Proof" is a nebulous concept, I guess. How many anecdotes are required before they become proof?I don't think so. I think it's clear higher quality oils do better in these newer, higher power/displacement engines. Proof abounds here. So many people with oil burning now.
I bet that engine wasn't a high compression, strung out GDI turbo, was it?I just replaced my 4runner with over 400k on it. It was in my family since 30k, and mine since 170k. It got chevron, super tech, or Quaker state every 5k miles. Sometimes high mileage formula. I was even using conventional in it until that wasn't available, then it was synthetic blend. I'm in the camp that says clean oil is what counts. For a high performance engine or extreme conditions I might be more picky.
