- Joined
- Oct 20, 2018
- Messages
- 127
Another thing you may want to consider, being a Subaru, is if the front is tweaked a bit (and along with it the engine/cradle), this car will absolutely decimate universal joints. Which are not replaceable except as part of the a driveshaft assembly. Many risks here.
Also, this is an engine that may end up being a valve seat problem, and already is probably one of the ones that eats oil. Will O2s and cats last? Will it need re-ringed? If it's nearing 90k, it won't be that long before it needs struts (which are Subaru only and $$$$), hub/bearings, axle shafts, and rear upper control arms (every Subaru needs them or has had them replaced). These aren't free-to-run high mileage animals.
Edit: by "valve seat" I meant valve spring. Subaru is recalling some, for now. Many more may be affected, and how many miles will they still offer the free fix until?
Now, as a flip, this is a super hot, in-demand, popular vehicle with sky-high resale. The parts are also worth a ton. Money could be made.
