I have also used 2 cycle tcw-3 rated oil in my 95 towncar tanks, and many of my other car and truck gas tanks. It seems to smooth out the compression quite a bit for me. Whereas 99% of my driving is hwy, easily 250-300 (roundtrip) miles per day between 2 driver's in the household. I was using the semi synthetic Mecury marine tcw-3 rated, and then I just switched over to Walmart's version in the blue gallon jug. This stuff works very well for me. It helps to fight corrosion within the fuel system, in addition to keeping everything clean and well lubricated. And the fact that its an ashless product is key! I use to use Lucas upper cylinder lube, but the 2 cycle ashless is much more feasible and cheaper, and I think more potent as a marine oil regarding corrosion protection. I don't experience any solvent exhaust smells, and or any carbon issues. And my cel hasn't illuminated. Most important, my plugs give an all clear with regards to any soot/carbon deposits. I have been reading that Walmart's 2 cycle ashless tcw-3 in the blue jug (it clearly states "ashless" unlike many others in its class), has a 60/40 ratio base of solvent/lubrication additive package. Is a 40% lubricant additive sufficient and or effective? And or how well does a 60% solvent additive package clean. I am not really worried about deposits into my motor oil, whereas., I am always on the hwy at sustained speeds averaging 65-75 mph. What say you?
Best Regards!
Best Regards!
