Originally Posted By: CharlieBauer
Originally Posted By: Ducked
You skipped the first bit
"Viscosity was the only variable you specified, so its the variable I queried, and its the variable under consideration here. "
You advised him to get the
lowest viscosity that meets the spec. You didn't say
"It could be that some low viscosity oils are actually better than their viscosity would suggest"., nor did you make any specific recommendation of a superior low viscosity oil.
OK, I'm advising him to get the
highest viscosity that meets the spec. Thats equally abstract but opposite. It might not
guarantee the best possible protection, but I'd say its a better bet.
Let me ask you to recommend another oil then. Euro application requiring min HTHS of 3.5. Vehicle designed for autobahn but won't see over 80mph. Driven in a mild climate.
Do we choose the 0w40 solely because it has a HTHS of 3.9 or a 5w30, 0w30, 5w40 with a lower HTHS?
Sorry, can't do that.
If I needed to use such skinny oils I'd try and find out about them, though that probably wouldn't be easy. For comparison, I've used SAE 40 and 15W40 in my current car, which, IIRC specs SAE 30 or 10W30.
What you suggest sounds reasonable, but in practice I'd be uncomfortable with anything starting with zero and might go for the 5w40. That's a predjudice and I have no technical defence for it.
Realising that my thick oil thing was largely intuitive, plus anecdotal accounts like this one
http://www.machinerylubrication.com/Read/518/motor-oils
Motor Oils - Fuel Economy vs. Wear
and opinions expressed by people on here who have a track record of seeming to know what they were talking about, I had a quick Google for easily accessible research on the relationship between viscosity and wear. As seems to be normal with basic oil-related questions, I didn't find much.
http://www.sciencedirect.com/science/article/pii/S0301679X15003709
Low viscosity engine oils: Study of wear effects and oil key parameters in a heavy duty engine fleet test. Tribology International. Volume 94, February 2016, Pages 240-248
"Slight difference in wear was detected due to LVO, mainly dependent on engine design."
Low viscosity oil (LVO) was associated with more wear (though this was measured by emmission spectroscopy so is questionable) for the two types of diesel engines, especiially for the flat tappet design, but less wear for the CNG engine.
Macian, V., Tormos, B., Ruiz, S., Miró, G. et al., "Evaluation of Low Viscosity Engine Wear Effects and Oil Performance in Heavy Duty Engines Fleet Test," SAE Technical Paper 2014-01-2797, 2014, https://doi.org/10.4271/2014-01-2797.
From the online abstract (I don' pay for no steengkeeng SAE paper)
"Results indicate that oil performance and wear effects do not show abnormal patterns due to use of LVO."
Uh-huh. Interesting choice of words, rather suggestive of an agenda . This seems very likely to be the same study, so, since the LVO wear is higher, why not just say so?
"do not show abnormal patterns due to use of LVO" obscures that fact, but in its context would imply that higher wear is normal for LVO.
http://pdf.blucher.com.br.s3-sa-east-1.amazonaws.com/engineeringproceedings/simea2016/PAP20.pdf
Low viscosity oils impact on Heavy Duty Diesel engine components
Edney Deschauer Rejowski, Dr. Eduardo Tomanik, Juliano Pallaoro Souza
MAHLE Metal Leve SA (Downloadable)
Compares
"a SAE15W-40 (HTHS 3.7cP) currently used in Brazil and a 10W-30 (HTHS 2.9cP) candidate for the European next generation engine" but looks at some 0W/x oils as well. Lots of graphs showing greater wear on the lower viscosity oil, though the thicker oil showed more blowby, which I wouldn't have expected (see table 2)
There was some Google Books stuff as well but thats too bloody difficult to read.
So not a lot found, but for what its worth, it tends to support higher wear for lower viscosity oils
