OP talking about an OIL filter not air filter. Any dust entering the oil system probably would go through the PCV which is filtered through the air cleaner.Ain't much dust and such up to get sucked up there though.
Yeah they are apologetic about it. They also said the technician that did the job 1 year ago no longer work there for another reason and would probably get fired again for this. But I don't know what else they could offer me, since the damage is done and probably long term and won't show up in short term.
Doubt OP would trust that shop anymore.How about some free oil changes for your trouble.
Is there a part number on the old filter? Do you have pictures of it?
Rather than 100% shop fault, the filter may have been manufactured incorrectly.
My ex-landlady's '55 Chevy made it well past 100k miles with no filter, and no engine problems.Up until and through the 60's, many cars did not come with oil filters standard. The manual on a 1962 Pontiac I once had mentioned the oil filter as optional equipment.
Evidence for what though? There's not going to be any recourse if the engine fails at say 50k miles or 80k miles or whatever mileage. It would be basically impossible to link a failure to this issue.I still have filter, kept as evidence. It is a different part number and it is made right… for that part number.
Very interesting chart. Do you have the source or a copy of that report, would love to get a copy.Running an engine without an oil filter shouldn't have a huge effect on wear. Over the life of the engine, it might be enough to cause the engine to wear out prematurely, but over 2,000 miles it's nothing to worry about. If it was running without an air filter, that would be a lot more concerning.
It's from SAE 460133 - Oil Filtration and its Effect on Wear (1946).Very interesting chart. Do you have the source or a copy of that report, would love to get a copy.
Working at a forklift dealership [ we would see high hour engines] the engines with full flow filters would have pretty much double the life of the engines equipped with a bypass only oil filter. That being said air cleaners are probably the more important filter [ the newer forklifts had the Donaldson air filters] when considering the ability to filter small particle sizes. Engines will, with proper care and luck of the draw outlast the vehicle despite the oil filters particle filtering ability.Running an engine without an oil filter shouldn't have a huge effect on wear. Over the life of the engine, it might be enough to cause the engine to wear out prematurely, but over 2,000 miles it's nothing to worry about. If it was running without an air filter, that would be a lot more concerning.
Here's another good engine wear vs oil cleanliness SAE study - much newer than 1946.
PDF download link
Summary
Beta 75 is 98.7% (call it 99%) efficient, aka: "Absolute" efficiency.
Interesting study. I like the fact that they did a wear metal analysis of the used oil as well in addition to the direct wear measurements.Here's another good engine wear vs oil cleanliness SAE study - much newer than 1946.
PDF download link
A used oil analysis might not tell you a whole lot, unless wear is unusually high. A used oil analysis was performed in this study, and the 60-micron filter only showed around 30% more wear metals in the used oil compared to the 10-micron filter, despite the fact that engine wear increased by 700%. If the oil filters used were identical and the 700% increase in wear was caused by some other factor, there may be an even smaller increase in wear metals measured in the UOA, since some of the wear metals small enough to have shown up on the wear metal analysis in the study would be trapped in the 10-micron filter, unable to be measured.And with 60micron filter (basically rock catcher?) is only 8x worse than 10 micron filter... Anyway, the oil report I am gonna get in 2 weeks is gonna tell the real story.
What are you expecting it to show exactly?Anyway, the oil report I am gonna get in 2 weeks is gonna tell the real story.
This paper is citing two different studies. One is for a field study. One is for a lab testing (which they added a ridiculous amount of junk in the engine). This graph is from the field study where the graph ZeeOsix quoted is from the lab testing, I personally do not think the lab testing reflect real world conditions, as no engine is gonna see 400 grams of pure dust in the engine. The lab testing study was done by a company that sells oil filter too... so it is less crediable, they might just be wanting to selll their new fancy filter.Interesting study. I like the fact that they did a wear metal analysis of the used oil as well in addition to the direct wear measurements.
I'm not sure what the reasons are that wear metals track so non-linearly with actual engine wear, but it's consistent with what we commonly see with UOAs. The standard deviation in wear metals from one engine to another is quite small, even though we know that there should be huge variances in wear rates between different engines based on engine load, trip duration, ambient dust concentration, air and oil filter efficiency, etc. Trying to measure even a doubling of engine wear with a wear metal analysis is pretty much futile. This is why engine wear is physically measured in these old studies, and why more modern studies use radioactive tracer methods.
I propose that we lobby auto manufacturers to install radioactive piston rings in their engines so that BITOG nerds can better measure wear with an oil analysis![]()
And this is exactly the problem with isolated and even sequential UOA. The “testing” environment is completely uncontrolled, and any results from the spectrographic analysis are influenced by any myriad of factors. There is absolutely no way one could confine an isolated variable to the results that are obtained. You can see the results, but you have no way of knowing what to attribute them to.Interesting study. I like the fact that they did a wear metal analysis of the used oil as well in addition to the direct wear measurements.
