- Joined
- Aug 4, 2020
- Messages
- 557
*I'm not asking for professional electrical help, just asking if something seems obviously incorrect/correct. I will be seeking professional advice either way*
I recently had a professional electrical contractor install [among many things] a new 220 outlet (it's a 30A receptacle that looks similar to the image below and new wiring to an existing 30A breaker (which was used at some point, but they ripped the outlet out, capped it, and left the breaker empty. I just wanted to clarify the 30A breaker is not being shared).
More recently, a friend came over and installed this compressor for me in my shop. He's not a licensed electrician to my knowledge, but he's a professional diesel mechanic who is required to diagnose and fix literally any [electrical] problem on first responders' vehicles. I consider that mostly qualified. I do understand that does not mean fully qualified, hence why I'm here asking about it. He installed the box (starter?) for the compressor and wired it up with a new cord and had it running fairly quickly. When the compressor runs, it seems to run perfectly fine. But while it's running, the lights in the shop aren't too happy. They surge the entire time it runs. The best description I can give is a very minor strobe effect, or as if someone is rapidly alternating a dimmer switch between 90% and 100% brightness over and over. I didn't really give it much thought, because I need to upgrade the shop breaker box anyway considering some of the breakers are double tapped and it's at capacity (it can only hold 6 single or 3 double breakers). I already purchased a new breaker box & breakers, and plan on dividing up some existing circuits and making new ones to prevent any possible overloading. It just hasn't been installed yet.
Well, the compressor has only run about 5 times since installation, and tonight while it was running (and the lights were surging as usual), apparently the lights in the house were surging also. I guess they always have and I just never noticed. Before anyone asks, I have no idea if they share a main breaker. I'd guess they'd have to if it affects the other. But when the compressor ran tonight, one of my recessed LEDs in my kitchen (also installed by a different licensed electrician 6 years ago) fried, and almost caught on fire. I didn't know it until about 20 minutes later when I went in and noticed the light was out. When I pulled it down to unclip the harness, I instantly smelled that horrible burning electrical smell and quickly unplugged it, unhinged it, ran it outside and set it on concrete, then grabbed the fire extinguisher as a precaution. The odor was strong enough to make my whole house stink. Pic below.
Long story short, I think it was way too coincidental for these not to not be related. So my question is this: is my compressor on the proper receptacle & breaker amp rating? In other words, is this compressor designed to run on a 30A circuit? 40A? 50A? Here's every bit of info I could find on the compressor. Pic of the entire compressor:
Pic of the model number:
More info:
This is located physically on the tank:
This is located on the grey cylinder-shaped piece on the top, which I'm assuming is the electric motor...?:
Last, here's the starter:
What are your thoughts? Does this appear to be wired correctly? Do I have the correct breaker/circuit @30A? Thanks in advance for your help.
More info:
