Shift kit in a 4R70W, good or bad?
Arizona
I was thinking of doing a Transgo shift kit in my Mark VIII and was wondering what everyone's thoughts were on this? I've heard they are good and others say they are bad on the 4R70W.
I ask because it's either this or the Jmod, and the transgo is a much cheaper option(labor wise) 225.00 for Transgo and Parts vs. 570.00 for Jmod and parts.
Wish I had the tools/knowledge to do it myself.
Thanks.
Thanks for the input. I definately would prefer the Jmod but not sure why they want so much money for it(parts plus 4hrs. labor).
Or does 4 hrs seem fair? I heard if you know what you're doing it doesn't take long.
Still undecided but if I do a shift kit it will either be the Transgo or the Baumann(also designed by a Ford engineer).
I put a Gregg Evans Factory Tech Valve body in my 4R70W (2000 Harley F150) the new valve body is made from 100% ford parts and is an easy swap. I wouldnt have done it any other way.
Gregg Evans was a transmission engineer for ford and designed these valve bodies.
I put it in when the truck had 45K miles on it, it now has 157K and shifts strong just like new.
I had these URL's bookmarked a few years ago, because I planned on doing the J-Mod on my Grand Marquis. Might be of some help:
Lincoln Mark VIII 1-5
http://www.cardomain.com/memberpage/496399/1
4R70Wnotes.pdf
http://www.crownvic.net/tech/4R70Wnotes.pdf
SHIFTY BUSINESS.htm
http://www.tccoa.com/articles/tranny/shiftybusiness.html
VALVE BODY MODIFICATION INSTRUCTIONS.htm
http://www.tccoa.com/articles/tranny/transmission/shiftybusiness.shtml
Why the cooling mod is important.htm
http://www.mercurymarauder.net/forums/showthread.php?t=10004
TCCoA Transmission Article - Page 13.htm
http://www.tccoa.com/articles/tranny/transmission/page13.shtml
TCCoA Transmission Article - Page 14.htm
http://www.tccoa.com/articles/tranny/transmission/page14.shtml
http://www.tccoa.com/articles/tranny/shiftybusiness_files/accum.jpg
http://www.tccoa.com/articles/tranny/transmission/d97.jpg
Holes in Trans Seperator plate.htm
http://www.tccoa.com/articles/tranny/plugging.html
Thanks for those links, all good sources of information.
I'm not doing anything to the car right now. If I do, I might use a pre-done valve body, such as the one from Blue Oval Chips.
