Hi @Rock_Hudstone, we wanted to share with you some information from a technical bulletin highlighting the recent industry change associated with the introduction of the API CK-4/FA-4 categories. This change has taken place due to an agreement by API members and engine manufacturers to amend the API requirements for allowing diesel engine oils to historically claim gasoline category approvals.
Previously, heavy duty engine oil marketers could claim an API gasoline performance standard on their products if they met CJ-4 and the required performance tests for gasoline standards. The recommended viscosity grades for modern gasoline engines are XW-20s and XW-30s. As such, this waiver process is being phased out. Heavy duty engine oils which are XW-30s (and which claim API CK-4 approval) cannot also claim API gasoline standards, unless they meet the current phosphorous requirements/limits. With that said, The new fully synthetic Shell ROTELLA® T6 Multi-Vehicle 5w30 is one such product that meets the performance requirements of API CK-4 as well as API SN and is formulated with 800 parts per million of phosphorous, which meets the API SN requirements.
While the industry waiver is still currently in existence for heavy duty engine oils that are XW-40’s, this remains in discussion to be addressed by the API in the near future.
However, as a leader in the transport industry, the Shell ROTELLA® brand has made the decision to remove API SN claims, regardless of viscosity, from our other products which do not meet the preferred low-phosphorous chemistry for gasoline engines. It’s also important to note that there is no change in formulation associated with this change. It simply means that Shell ROTELLA® products will no longer claim formal API SN approval for products other than our fully synthetic Shell ROTELLA® T6 Multi-Vehicle 5w30 on labels, technical data sheets, rotella.com and marketing materials moving forward.
- The Shell Rotella Team
