Shell Helix HX8 5W-40
FCD
Mallorca, Balearic Islands, Spain
I've been thinking that after changing the hydraulic lifters in my 1988 Escort which will hopefully make it nice and quiet i've been thinking it could use some Full Synthetic to do some cleaning.
I've found that i could get Shell Helix HX8 5W-40 for a pretty reasonable price locally.
The factory spec for this engine is simply 10W-40 API SF.
These Ford CVH engines are prone to cam lobe wear as the valve springs are very stiff already from the factory, it seems to have around 1100ppm of Zinc from a used oil analysis i found over at oil-club.ru which is good.
Anybody know how it compares to Helix Ultra 5W-40 in terms of base stocks, HTHS, Saps content??
Guess you missed the comparison table page at the russian oil club:
https://www.oil-club.ru/forum/topic...-tablica-laboratornyh-analizov-oyl-klub/
In short the Ultra is a "cleaner", less sulfurous oil, with a bit lower NOACK.
Has a bit of Boron extra. Otherwise very close. Saps I think is Зола СулфатнаÑ, which is
1,09 v 1,13 % of content, well within the margin of lab error. HTHS is not tested, so no data.
One caveat - its 2014 vintage data, so things may be very different.
