It's been proven time and time again that the 5w-40 and 10w-40 oils quickly shear out of grade in a shared sump motorcycle engine. My question is, why would 10w-40 be the most common recommended oil weight by the manufacturer's? They must know that the 10w-40 grade shears, and yet they still recommend it. The only explanation I can think of is that a sheared down 10w-40 oil must still be providing adequate lubrication. I find it hard to believe that the manufacturers would recommend a 10w-40 oil if it were a problem. Thoughts?
I mean, we routinely see 10w-40 oils shear down to a 30 weight by 1500 miles, yet most of the OEM's recommend around 4000 mile OCI's. This must be an acceptable result, otherwise it wouldn't be a recommended type of oil, right?
