I'm a newbie, although I have been reading this forum for a little over a year, so please bear this in mind (be gentle)...
I have a 2003 Suzuki SV1000S (motorcycle, but using a car oil so unsure of proper location)
1 liter, V-twin, water cooled, shared sump with transmission, and wet clutch.
OE recomends 10W-40
Currently using Rotella T synthetic 5W-40, but worried about shear stability since its not a true synthetic. Doing 2000 mi intervals, but would like to go out to 4000 (I know I should use a used oil analysis)
I know from reading all the wonderful posts on hear that a conventional 10W-40 would die (shear) rather quickly in a shared sump application.
I also know that todays energy conserving motor oils can cause problems with a wet clutch due to friction modifiers.
I want an oil I can get easily when I grab my car oil at the local X-mart (rotella T synthetic in car)
What I am getting to is...since Mobil 1 5w40 is rated for diesel engines, I recall that one of the diesel specs is for use with wet clutches. If someone could confirm that spec is on the label, and is not energy conserving, I think I will have found the perfect oil to use in my bike!!! What do you all think?
OE recomends 10W-40
