Share your gas saving tips...
I fit the gun to the need.
I have always driven smaller cars.
This is a huge factor.
Manipulation of the gas pedal is #2, assuming the car is in great running shape. Around town or the highway.
Tire pressure? 2-4 over the factory is proven safe and will help a bit, esp on the highway.
I'm finding that the most fuel efficient way to drive my old BMW is to run it like your hair's on fire through 1st and 2nd and then drop it into 5th when you get to whatever the speed limit is. Coincidentally, this is also the most entertaining way to drive it.
Originally Posted By: Burt
Gently accelerate up hills and put it in idle going down hills. This reduces your average rpm's.
I assume you mean to put it into neutral, and that's not an effective way to save fuel, at least on most cars. Most fuel management systems cut fuel at idle, and especially with manual transmission cars (but increasingly with automatics as well). So as you coast down a hill, you use NO fuel if you leave it in drive, but it would use SOME fuel if you slip it into neutral.
Comments about letting the fuel injection do it's job are right on the button. Coasting with many of these systems means no fuel is flowing into the engine. Taking it out of gear or holding in the clutch messes up the process and burns more fuel.
Originally Posted By: gfh77665
I just siphon gas out of my neighbors truck in the middle of the night.
Shop online and pay shipping. Depending on the product, it may be cheaper (and less time consuming) to have it shipped instead of driving all over town looking for a not-so-common item (e.g., faucet cartridge).
Only if you need engine braking not to speed excessively. If you can coast on the flat after the hill with the extra speed you gained without engine drag, then you're saving more gas overall.
Maybe we just have the right sized hills here but I don't need to brake on them coasting in N, and then the car can continue to get 120mpg for quite aways after the hill. Traffic permitting I let the car coast down from 65mph at the base of the hill to 45 or 50mph and then resume my regular 55mph. Its really just gravity assisted pulse and gliding.
Slow down, get to speed and maintain it, and keep the tires inflated. At 55 mph my Buick will get about 35 mpg given long enough. It gets 25 mpg at 70 mph, and ~30 mpg at 62 mph. On long trips it saves quite a bundle to slow down and smell the roses. The Fit sees even bigger gains slowing down to 65 mph from 75 mph due to its tiny engine needing to work far harder at 75 mph.
I am itching to start aero-modding my Buick again. Taping up the openings on the $15 hubcaps is proven to get me a couple MPG on the highway. It smooths out the surface the air has to pass over.
Originally Posted By: daves66nova
Use a vacuum gauge.You'll be surprised at how easy it is to go in the red,where you waste the most gas.Using a grill block should also help. www.ecomodder.com is a good site for this
http://www.youtube.com/watch?v=MBYVZLRyQjk
That also refutes the notion that using CC increases fuel mileage.
I might get a vacuum gauge! The problem with that is, spending even 20 bucks to improve fuel mileage a gallon or 2 isn't economical. Doing things that don't cost much money are the only economical ways to reduce fuel usage and save money.
Originally Posted By: GROUCHO MARX
My MPGs have really been getting lower. I think my neighbor may be siphoning gas from my truck's tank in the middle of the night.
Originally Posted By: willix
90 mpg
No thanks! If I'm going to be maimed by a vehicle ten times the weight of the one I'm driving, I want to at least have had the pleasure of regularly enjoying 3-second 0-60 sprints!
I optimize fuel economy by staying at or close to the speed limit on the highway and freeway, by avoiding brake usage, and by quickly getting into the highest gear possible.
Originally Posted By: Craig in Canada
Use public transit
No public transit within 50 miles of me, and certainly none at 4 AM when I leave for work!!!
Originally Posted By: Pop_Rivit
Originally Posted By: NHHEMI
Good ideas except #2 is not contributing to your increase in MPG(IMOA). Using CC on the highway actually helps your MPG as the vehicle maintains a steady speed at the optimum speed/RPM range for the vehicle. While you may be saving a very tiny, minute, amount of fuel going up hills and letting the engine slow down vs the CC giving it more gas to maintain speed, as you say, the CC actually would be saving you more on the flat sections than it is costing you on the hills.
That simply isn't correct in many circumstances.
I can easily gain a 2-3 MPG trip average by coasting uphill and letting gravity help with some of my acceleration downhill. While I don't advocate or practice it on the Interstate or when there is traffic on a 2 lane highway, I frequently do it on my way to town, especially early on a Saturday or Sunday when there isn't any traffic.
I take it a step further and allow my speed to drop from 60 MPH down to about 45 MPH. Then on the downhill side I gently bring the speed back up to 60 in anticipation of the next hill, trying to time it so I hit 60 just as I begin the next climb.
I'll agree that using the cruise control on relatively level terrain works best. But on my hilly drive, when conditions are right, I'll achieve a better result by using my foot and following the above technique.
2-3 MPG simply isn't "tiny, minute" amount of fuel in my book.
1st off what you are talking about is not normal driving and it takes a concentrated effort on the driver's part to achieve. Something most people would not bother with. It is also akin to hypermiling and in some states it is illegal to drive like that( minimum speed laws, laws against coasting out of gear or with no clutch, and some new specific hypermiling laws ). My comments are related to the OP's comments in which he/she states they use the accelerator manually up hills and then let off on the other side vs letting CC do it to save fuel. That is not the same thing you are talking about as you are talking about costing both sides. I stand behind my comments made when you take the OP's comments and my response on the whole.
Secondly, by your own admission, you are talking about a driving practice/technique to save fuel that is not safe for use in normal traffic so it does not apply IMO to this discussion nor to my answer which concentrates on what the average person can do driving to save fuel. Not everyone drives early in the AM or late at night when no one else is on the road to do what you posted. Try and do what you suggest around here and the Police would pull you over or the other drivers would run you over. Set CC at your optimum speed( 60 MPH +/- for most highway )and let it do it's job whenever it can be used vs you running the accelerator. Over a full tank and all of your driving it will consistantly return better MPG than the average person can do with their foot.
What you suggest may save the fuel you say it will( I have doubts it is that big of a savings but??? ). It is not a safe driving technique however for the average driver and as said in many states it is illegal to drive in that mannner as it would be considered hypermiling or it would break minimum speed laws, vehicle in gear laws, etc...
If folks planned better and slowed down by 5 mph they'd arrive less stressed out and get better fuel economy. And the "time" saved in a typical trip by speeding is measured by seconds anyhow.
Obviously this doesn't take extenuating circumstances into account such as emergencies or weather-related things. Pedal to the metal when getting a loved one to the hospital or outrunning a tornado.
You can not do this in Miami Dade County or Broward County...You must drive 5 to 10 MPH over the speed limit at all times out on the interstate [unless traffic volume is high which it is for the most part during the week] or you will be rear ended or worse yet be involved in a road rage incident and be shot or beaten to death...Things like that happen all the time down here.
Getting beaten to death is quite the extenuating circumstance.
Have you ever noticed freeway traffic that travels in bunches? You can fall off a group of cars and be in a completely open space until the next pack catches up. Recently I worked on a job that involved a 100 mile one way commute every day for a few months. By falling back into open spaces and driving just off the pace I was able to arrive at work fresher and got better gas mileage at the same time. Many times the open space lasted 20 miles or more and it was kind of peaceful having part of the road completely to myself. My commute times were about 5-10 minutes slower and I listened to books on CD along the way. It made for a much better commute for me and better gas mileage was an added bonus.
