Shall I test MolaSoak or something else?
Michigan
Hi. I have a street/strip Chevy 350 that I did a head swap on two winters ago. I recall how much carbon was on the pistons, and because I'm going to swap this engine out at the end of the season, I thought it would be a perfect opportunity to conduct a somewhat rigorous test of MolaSoak... or water, or Seafoam, or something else. I'll at least look at the pistons through the spark plug holes and exhaust ports, or I might tear it down completely; it depends on what I decide to do with the engine.
So what do you think? Decent experiment design, considering its opportunistic nature? Which treatment should I test? If I test something that is also supposed to clean the rings (which I bet are carbon'd up too), I can also do a before and after compression test.
How about one of each. LC, Molasoak, water, Seafoam, B12 Chemtool, GM Top Engine Clean, and Mopar Combustion Chamber cleaner, and ATF. See which one works the best, then soak the rest of the pistons it in the next night.
