So my Grand Marquis had a shake when the brakes were applied and a rattle on driver's side when I hit bumps.
I took the front rotors off to see if they could be turned. No luck.
When I took the calipers off I discovered the driver's side caliper slide pin bolts were missing leaving the pad holder totally lose.... WTH?
Got new rotors and a slide pin kit. All is smooth and quiet now.
