SHAES-429 vs GL 4 OR GL 5
What is the difference in the API GL (4 or 5) spec and the HD spec of SHAES-256 rev C and the SHAES-429? I've done some exhausting reading, but coming up empty minded!
Well, the simple explanation is GL 4 or 5 are API standards whereas SHAES are Dana Specific specifications that may go above API standards.
I found this PDF & on page 6 it shows different mileage change requirements depending on HD or Medium Duty trucks. Also Line haul vs Vocational interval.
https://media.spicerparts.com/cfs/files/media/yxkjTcTZwjrfmQtJg/LM072012.pdf?store=original
Use GL 5 instead of GL 4 since it's more robust.
https://blog.amsoil.com/the-difference-between-gl-4-and-gl-5-gear-oil/
However, if you have a Dana axle you're putting this in you need to go by what Dana specification is but if you can find API GL-5 with that specific Dana specification then voila.
