JHZR2
Staff member
Hi,
I have an analysis of what some would call severe service. My mother's 1997 Plymouth Breeze (2.0L engine, automatic trans) is operated as follows: start drive 5 blocks in the AM, Start drive 5 blocks 3.5 hrs later, start drive 5 blocks 45minutes later, start drive 5 blocks 2 hours later. Yes, five days a week, the car gets used to drive five suburban blocks 4 times a day. It also gets used to drive to the shoprite which is a mile or two away, to my brother's hockey practices, which are 5 miles away. On the weekend, it usually gets driven aboiut 200 miles, all in trips over 15 miles each (two of them being 72mi).
I figured this is pretty severe service. The car usually doesnt warm up, and if so, just barely (im sure the oil isnt warmed up yet). The car operates more in the 0 or 5w- range at cold temps than in the -30 range such as when it is hot.
The oil is a mixture of 2.5qts M1 0w-30, 2 qts M1 5w-30. No additional oil added. Filter was the Supertech model for this engine (ST5593A or something like that cmes to mind).
I lost the paper that I had written the mileage down on, so I dont know the exact miles on the oil, but Id say it is about 4500mi. Figure the start and drive five blocks behavior M-F every week from Christmas to 5-12-03, plus the weekend driving on half of those weekends, and a few longer trips.
All in all, id say the M1 did quite well, but comments would be appreciated. Analysis done by wear-check USA.
DIAGNOSED by KeithS on Monday, May 19, 2003 at 10:49
Lab Number 00516502
Sample Date 5/12/2003
Unit Age 60240m
Time on Fluid 4500m
Time on Filter 4500m
Fluid Maint. Changed
Filter Maint. Changed
Fluid Mobil 1 0w-30/5w-30 mix (supersyn API SL)
Iron (Fe) 21
Chromium (Cr) 0.8
Nickel (Ni) 1.1
Titanium (Ti) 0.2
Silver (Ag) 0.0
Aluminum (Al) 8.2
Lead (Pb) 0.2
Copper (Cu) 2.9
Tin (Sn) 0.0
Silicon (Si) 11
Sodium (Na) 5.2
Potassium (K) 0.0
Boron (B) 142
Barium (Ba) 0.0
Molybdenum (Mo) 67
Magnesium (Mg) 20
Calcium (Ca) 2510
Phosphorus (P) 820
Zinc (Zn) 928
Sulfur (S) 2373
Cadmium (Cd) 0.0
Manganese (Mn) 0.5
Vanadium (V) 0.0
Soot(%) 0
Oxidation(PA)
Nitratrion(PA)
Sulfation(PA)
ZDDP 0.00
Kv@100°C 10.66
White Metal NONE
Babbitt NONE
Precipitate NONE
Silt NONE
Debris NONE
Dirt NONE
Appearance NORML
Odor NORML
H2O(Emul) NEG
H2O(Free) NEG
[ May 20, 2003, 10:03 AM: Message edited by: JHZR2 ]
Lab Number 00516502
Unit Age 60240m
Time on Fluid 4500m
Iron (Fe) 21
Chromium (Cr) 0.8
Nickel (Ni) 1.1
Titanium (Ti) 0.2
Silver (Ag) 0.0
Aluminum (Al) 8.2
Lead (Pb) 0.2
Copper (Cu) 2.9
Tin (Sn) 0.0
Silicon (Si) 11
Sodium (Na) 5.2
Potassium (K) 0.0
Boron (B) 142
Barium (Ba) 0.0
Molybdenum (Mo) 67
Magnesium (Mg) 20
Calcium (Ca) 2510
Phosphorus (P) 820
Zinc (Zn) 928
Sulfur (S) 2373
Cadmium (Cd) 0.0
Manganese (Mn) 0.5
Vanadium (V) 0.0
Soot(%) 0
Oxidation(PA)
Nitratrion(PA)
Sulfation(PA)
ZDDP 0.00
Kv@100°C 10.66
White Metal NONE
Babbitt NONE
Precipitate NONE
Silt NONE
Debris NONE
Dirt NONE
Appearance NORML
Odor NORML
H2O(Emul) NEG
H2O(Free) NEG
