So, I use Mobil 1 synthetic oil. I've seen a lot of unwanted varnish in dino lubed engines and a lot of scratches in synthetics long drain intervals. The problem with long drain with syn, is particle count. So I had an idea a few years ago. Why not use the synthetic oil for 5k miles and as a cautious measure, drain it out and storage it in a hermetic closed container, with a strong neodimium (rare earth) magnet at the bottom for decantaion and iron collection. So, I fill the sump with fresh synthetic oil, new filter, run for 5k miles and drain again at the end of these 5k. Then I Go back to the previous used stored (still good) oil to run it again for 5k miles with a new filter. When it gets 10k, the additives are depleted, I send it to recycling. And this goes on and on.
That way, by almost 4 months decantation, I put all those particles above 5-6 ... microns to the bottom of the container and when I reuse, I have a pretty well gravity filtered oil, without the use of a bypass filter. The dispersant gives a temporary dispersion and giving time most of the particles, specially the harmfull bigger ones, will hit the bottom and settle down.
I have saved a lot of oil and managed the risks
Just an idea that could be of interest for somebody afraid of todays long drain interval and particle count ...
