Serious discussion about 10W syn for winter
Anything less than 6000 miles on Mobil 1 Advanced Fuel Economy is a waste. There are UOA showing it can take up to 10,000 no problem.
Well, 10w30 was the default all climate grade in North America for decades.
Engines started and lived to tell about it.
What I'm trying to convey is that you could use a 10w30 this winter and would likely see no ill effects.
I'm personally not going to and see no real reason to, but you could do so with probably no harm at all.
You might consider running 10Ws during the warmer months and 0 or 5Ws during the winter.
That does seem a little retrograde though, given that multigrades exist largely to eliminate the need for seasonal oil changes.
Originally Posted By: kschachn
Originally Posted By: merconvvv
Because blending gives you more control and ease in achieving your target at a lower price.
If you can find something that meets your target on the shelf already in a can at a price you like then thats good too.
Since the W rating isn't a viscosity how do you know what mixing does to the rating? In other words, you are saying you know what the results would be of the mixing?
For the number after the dash, yes. But you're saying you know what it does to the other number?
If i came across as saying you could blend with a blindfold on, then i am sorry.
In my opinion as an example, 50 50 blend of Pennzoil Platinum 5w20 and 10w30 will have better ccs than 100 percent Pennzoil Platinum 10w30.
But it is not safe when trying to fine tune cold cranking characteristics.
I have 5 quarts of Pennzoil Platinum 10w30 and 1 quart of Mobil 1 Extended Performance 0w20 in the ford. Only had 1 jug of Pennzoil Platinum and leftover Mobil 1. Sure does crank a lil easier.
But the example given above with Pennzoil Platinum 10w30 and 5w20 i dont see any problems if by chance there is then i am just as bad as the gm lube dept that is now switching to 5w30 and keep coming up with new standards
It shouldn't be a problem, and likely won't but it could be. If you're trying to optimise for cold starts, it's best to let the formulators handle the issue.
In your current mix, do note that you're also not right now anywhere approaching the limits of MRV. With ambients right now, you're not even coming close to stressing a monograde's starting limits. A thinner lube will crank easier, sure, and adding a 20 to a 30 thins it out. What happens at MRV limits is a little less predictable.
If one is looking for something with shear stability and still being suitable for the winter, there are all kinds of A3/B4, A5/B5, and HDEO options in viscosities including 0w-30, 5w30, 0w-40, and 5w-40, none of which will compromise cold weather performance.
As I've said many times, if someone sees a problem with an ILSAC 5w30 conventional (and I'm not convinced there is a problem in most cases), then an ILSAC 10w30 isn't the solution. Right near the 10w30 on the Canadian Tire shelf (Saskatchewan Canadian Tires actually have very few 10w30 synthetics; they've been cleared out and haven't been replaced) are things like Mobil 1 0w-40, GC 0w30 and 0w-40, and Pennzoil Platinum 5w-40 A3/B4.
No, and please don't take it as though I was suggesting there is a problem. I just haven't ever seen a "W" calculator that gave cold cranking performance standards for mixed oils. I always assumed it was more of a function of the specific additives in the oil and as such couldn't be calculated even if you wanted to do so.
For me, if I am starting at temperatures below zero (as I do here in the winter, especially for the BMW) then I buy a 0W oil. If not, then I buy something else. I guess I'm not convinced of the need to mix anything to achieve cold weather performance.
Pennzoil Platinum 10w30 has better noack than Pennzoil Platinum 5w30 and much better than most 5w30s.
Thats why i said you cannot blend with a blindfold.
I still say 50 50 blend of Pennzoil Platinum 5w20 and Pennzoil Platinum10w30 has better ccs than 100 % Pennzoil Platinum10w30 even in cold temps.
But in this instance just be aware that the resulting mix carries no standards. You cannot say for certain it even meets SN, assuming that's what the individual oils all meet.
It very well probably does. But why not use a 5w30 if that is your goal?
Yes the whole idea is to blend according to meet your personal standard with your money and costs. I wud not do it in a newish car with a warranty.
OP already blends 5w and 10w.i think.
OP wanted low noack etc if i recall.
He could pay through the nose for AMSOIL Signature Series or Mobil 1 ESP 5W30 then...or dig up some of the late, great, Pennzoil Ultra.
Guess it's cheaper and easier to buy the Pennzoil Platinum 10W30, especially if plugging in is an option on the really cold nights.
Originally Posted By: T-Stick
Unless I'm missing something ... if two pour points are equal between a 0w and a 10w, then this simply means the one is a 0w at start up and the other is a 10w. If flow properties are fine for both in a given temp range, the 10w should offer better protection when driving the car till it is warmed up to operating temp since it is using a thicker viscosity. How much protection does a 0w weight really offer when driving a cold motor?
The number in front of the "w" is not a weight, it is the ability for the oil to pump (MRV) and impact cold start crank speed (CCS). That's why you have 0w-20, 0w-30, 0w-40....etc in progressive order of thickness. They ALL get thicker as the temperature drops, the difference is the point at which they thicken beyond the thresholds for those testing parameters.
All oils are too thick when cold. The 0w will thin to the correct viscosity faster than the 10w.
To the OP question. Try it and see, I think you'll be fine. If you're short tripping I would consider one of the 0w multi-grades for extreme cold
We've been using primarily full synthetic 10w30 for the last 10-12 years. Mostly PP & Napa syn. Location : Colorado approx. 6200 ft. We live in the foothills in a large valley and temps in the winter can get extreme. Its not uncommon to hit -10 or lower. The valley helps to create some extreme temps, we have hit -25 3-4 times. Under these conditions we have run numerous vehicles with no issues, including a few high milers up to 212k. I'm not suggesting running a 0w or 5w in the winter wouldn't have benefits, just reporting the results we've had. Good luck.
With image credit to Richard Widman, note that a 10w-XX is required to pass MRV testing at -30. As mentioned, it's obviously not completely unusable in the winter. Some may face some situations where it's problematic, that's all. If someone has access to a heated garage or an oil pan heater, it would never be an issue; then again, a monograde would be suitable, too, in such a situation.
um no...
BTW, too thick to do what ?
