Sept 5 in Phoenix - Another temp record?
I suspect the urbanization of the area has raised temperatures considerably. Pavement and buildings absorb more heat than desert. The amount of new construction in and around Phoenix has been amazing.
My dad lives out in the middle of the desert about 100 miles west of Phoenix, and it's just as hot during the day. The difference is at night time it tends to cool off more out there.
I have a coworker who just moved there. I was asking if the central AC can still drop the home to 75F, when it's 115F....he was saying yes at night the house can reach 75F (it's not 115F at that time). How hard does an HVAC work out there? It would take a LOT of work to start at 115F, and reach 75F, if it could even do that. Not possible with the way our AC is sized in the northeast.
They work during the summer as hard as everywhere else, they’re just sized larger. A 2,000 square foot house up North probably has a little 2 ton A/C unit, where here it’s 4+ tons. Though they are running in the spring and fall too.
In the afternoons they run and run and run, if properly sized, and can keep a steady temperature. If you had it set at 78 and turned it to 74 at 4pm, it isn’t going to move the needle down much until probably 10pm.
No way! We have quite a few heat related deaths each summer and some are from people with non-working A/C in their homes.
It's all relative. High humidity and dew point are what make it unbearable. And you have far more of that in the Midwest.
A week of 100 degree weather in Chicago, and the elderly are dropping dead. Out here they're playing golf in it.
Looks like it was 1 degree off the record.
I got 115F on the dash and 115.9V on the KillAWatt (normally 121, but there’s 6 active power outages in the city).
It’s hot when the temp matches the wall socket voltage number.
