Seems like a lot of 1/2" sockets are 12-point, why?
North Alabama
Just a random observation as I shop here and there for tools. I've noticed a lot more 1/2" sockets available in 12-point vs 6-point. Anybody have any insights into why this is, or am I just imagining things? I've rounded off several fasteners over the years using a 12-point socket when I should have been using a 6-point; lesson learned. Who uses 12-point sockets, and for what?
Many of my 1/2” drive sockets are 12 point, but I haven’t had any issues rounding fasteners with them. All of my wrenches have 12 point box ends, and no problem there either.
My guess is they are all decent brands and all have “flank drive” where the socket contacts the sides and not the corners.
Also most 1/2” drive tools are generally used on larger fasteners, which should have less likelihood of rounding.
I also live where cars aren’t rusted up to the window with rust, which helps quite a bit.
Because the medical lobby wants money fixing skinned knuckles. ;)
But seriously, I agree, it's stupid, unless lining up a 3-foot breaker bar on a beefy strut fastener or axle nut that's both "known hard" and which rust won't take away enough of the hex corners to matter.
This phenomenon converges on 11mm sockets, which in those Father's day kits come in 6 pt, 12 pt, long, short, 1/4 drive, 3/8 drive, and 1/2 drive. That's a dozen sockets before you also add in the dozen 7/16" that also work.
A few years ago I bought a pretty significant set of metric and standard 3/8 and 1/2 inch impact sockets. Impact sockets are 6 point. Pretty much all I grab from the tool box now. I still have all my normal sockets both 6 and 12 point.
Don
Enough responses in here to solidify my choice to put any and all of my 12 point sockets (don't have many) in the "never gets used" toolbox and forget about them unless some special use case arises.
Frankly if I were to buy more 6pt, 1/2" sockets today, I'd just get impact sockets then be able to use them with both an impact wrench and hand ratchet or breaker bar, but this is because I already have thin walled 6pt and 12pt to get into tight spaces.
I'll use a 12pt if the fastener looks *easy*, not high torque and not rusted, but then it's more likely I'd be using a 1/4" or 3/8" ratchet instead of 1/2". Really I mean, if I accidentally grabbed a 12pt that was the right size, I wouldn't put it back instead of using it on an easy fastener. I can't recall the last time I grabbed a 6pt and had to put it back to get a 12pt.
My entire collection is 6 pt sockets. I feared the day I had to touch 12 point bolt heads on our duramax, but the truck was replaced with something else.
What I wonder is why all ratcheting end wrenches are 12 point. It's ratcheting. Orientation is irrelevant.
For most cars built in the last 20 years or so, I haven't found a bolt I had to have a extremely thin walled socket for. Maybe just lucky, or maybe since everything is put together with automated tooling now the designers pay closer attention to it?
Now growing up it seemed I often had to go looking for thin walled sockets on all kinds of things - cars, farm equipment, etc. Of course I worked on a lot more things back then so who knows.
The smaller the bolt head the more likely you are to round it off with a 12 point socket...
Correct. The two things I've rounded off with a 12 point socket were oil drain plugs, both several years ago. For some reason both times I just figured any socket that fit the fastener would work fine, without giving it any more thought. After the 2nd drain plug rounded off I took the time to think about why it happened, and haven't used a 12 point socket on anything since.
