Many people, in order to completely drain the pan and torque converter, disconnect the hose coming out of the cooler, start the engine, and pump the system dry into a container. Then, they drop and clean the pan, replace the filter and pan, and refill with ATF. Here's an alternative, for pans with a drain plug, that I just thought of:
Drain and clean the pan, change the filter, replace the pan and drain plug, start the engine and pump the remaining fluid into the pan, drain the pan a second time, replace drain plug, and refill with ATF. This might be a little less messy.
Give me your comments.
