Hello,
I have been lurking here for a while and have come up with a question. To show how astute I have been in reading advice given on this web site, I will pose my answers to the question also.
I have a new Mazda RX-8 which I really like and want to keep running forever. I am also just as much of an oil "enthusiast" as practically anyone on this board.
The RX-8 hold 7.1 qts of oil. When draining the oil only 3.8 qts drains out. The remaining 3.3 qts stays in the oil coolers and rotor bearing/gear cavities. How should this affect my oil change plan? Does the recommended use of 5W20 oil affect the plan? Does the recommended not-to-use synthetic oil affect the plan?
My current plan is to go ahead and change the oil beteween 2000 and 3000 miles.
Some anticipated answers would be to have oil analysis done after a couple of 5000 mile changes to see how stable things are. Another comment would be to start using Lube Control. This would help handle the contaminated old oil, correct? Any recommendations on the oil? I cannot say I am happy about using 5w20 oil, but have read that 5W30 is practically the same after 3000 miles running. I think there is a little tendency for the rotary engine to dilute the oil with some fuel. Again, this is a subject for oil analysis. Thanks for any advice.
