Just found this interesting. There are many threads on this tire section asking about thoughts on off brand tires and even used tires. Most everyone is also into the best Possible oil.
Tires are the only thing between you and the pavement that touch the road. Most off brand tires take many many more feet to stop than the best in class tires. That’s more important than hths crank main bearing wear correlation.
Maybe we should use the cheapest oil and never change the oil filter an we could save money on tires since the car will die when the tires wear out.
A little sarcasm
A little sarcasm
