Quote:
It does support the reason I bought one though. Better filtration than the average joe...Hey...that rhymes.
Sure. If I have a notion to do something ...I'm going to accept things that support my choice and tend to not consider that which would put that choice in doubt. That's simple human nature ..if you think about it. If you pluck your money down on a set of roller rockers due to some dynamometer graph that someone showed you, you "need" to see that. Is the test result "real"? Most likely. Is it something to hold a parade over and start a campaign to promote it as the "must have" wallet drain of choice for all who consider themselves savvy and you're an idiot if you don't join in??
I hope that this filter is "all that". I really do. High end filtration is very expensive. Bringing SYNTEQ/NANO-FIBER media to the consumer level is something that hasn't been done before, IIRC. The distribution for such offerings is somewhat limited to industrial applications and tend to dictate prices that are just way out of whack with what the single end user is going to ante up for. Amsoil's unique niche market makes this possible and I'm glad this evolution occurred.
I'm a "beyond user" of Amsoil products ...so I surely want this filter to be everything that all of you are assuming it is now. That said, I want to be able to answer every challenge that someone can present to me with some depth of conviction. That requires a little more then the results of one test.
Quote:
Some people are just contrarians and like to play the devil's advocate, otherwise known as a "skeptic."
Is there something wrong with being convinced to a reasonable degree before putting one's personal seal of approval on something? I'm quite sure that you've got some opinions that are cast in stone about certain products (cars, appliances, etc.) that couldn't be changed with a ton of supporting evidence to the contrary. Likewise, if you've had favorable experience with said products, you would tend to discount those who say otherwise.
Was your good or bad experience "false"? No. Was it "the truth"? Yes. Does it totally discount all others assertions, which are just as "real and truthful" .......only to you. Does it bolster all those who had results that you, yourself, support in either factual experience or opinion ......only to yourself and those who hold such "belief".
As you can see, lots of factual evidence can swing both ways.
Quote:
Who's calling for "worthy justification and blind faith?"
You already had it. If I'm correct, you're a user of this filter before George got his test results in. You had to ...just to justify this level of defense of the results. Nothing unusual there. I'd find it atypical if you bought one and said that you didn't make a wise choice.
Quote:
It's a just a good example with facts to back it up.
It's one example with one set of data. You could compare that to one dyno run on one engine. Is the data "real" ..sure.
Again, the data is very encouraging. You're encouraged. So, am I
Quote:
There is nothing here to reasonably refute the poster's conclusions. Stop trying.
That's what a defense attorney says in the courtroom. It doesn't work that way in academia and elsewhere. Data is assigned the term "proof" only after it has been subjected to the most torturous gauntlet of critical review. Again, the data offered, so far, is encouraging that this is a substantially superior product.
Quote:
All this philosophical hogwash and what-if nonsense is dumb. Sheeeesh.
Well, I've got two tickets on the Space Shuttle where you are assured a 100% fatality rate every 200 missions. I'd say that 199 events would be enough to be "proof" that it's safe transportation to many ..many people. Some of them highly learned engineers. That's a statistic (sorta pulled out of my behind - the number isn't researched for "truth") and not my "belief". Being "smart" resulted in shock and awe at unexpected results. Being "dumb" says that you never say that you've got a grip on it all ...especially with just one successful test.
Again, I'm "beyond a user of Amsoil products" (hint-hint-wink-wink) ..but I'm not going to over promote something on one suggestive data point. I would prefer to have more firm footing before I proclaim something as the second coming of sliced bread. At best, you'll hear me saying, as you've heard someone like Terry state (in other words), that current data suggests that this product is taking automotive filtration to a higher standard in full flow filtration and that further testing will be forthcoming that will hopefully confirm/support expectations.
If that's "hogwash" ...then so be it
Again, I hope George's second run and 427's first run show like comparisons in their given environments. I want this to work too.
