Second Partticle Counts Complete
lindermant,
Sounds like a adequate sampling procedure to me. It'll be interesting to see if you can duplicate the results. Try to mimic your previous procedure.
Quote:
May just do that and see if it actually lightens up appreciatively.
My oil light stayed on for while after start-up even when filling the filter with oil. Heck it ain't too fast on a normal startup either. Neons are slow that way. But you can surely hear it. When changing oil I suspect the Oil pump galley drains pretty well and thus still takes a few moment without concern of the filter type.
Promise to write and tell all about it when it goes down. Suspect a couple months though to get to 3K. Might just nail it at 2K. We will see.
Great ewetho, I am looking forward to comparing notes. My oil light used to stay on for some time before moving to the Eao filter (empty filter just after oil change), now it just blinks on and off. I think this , given that your Neon's light stays on for a long period of time, would make an interesting observation.
Harry
Harry
Harry,
Did you also switch to the 0w30 when you switched filters? Maybe that explains the light going out faster? On that subject, the location of the sender will skew any possible comparisons between vehicles. For instance, if the sender is mounted on the filter adapter directly before the oil enters the filter, the light will go out immediately if the filter is plugged causing an 11lb pressure increase to open the bypass valve. Some oil lights I have seen go out at a very low pressure, sometimes less than 5psi. If the sender is mounted in the galley further along, lower pressures will be seen. I think the purpose of an "idiot light" is to tell the operator that there is no oil in the pan, or the level is so low that windage is causing the pump to suck air. A more accurate indicator would be a gauge mounted further along the oil passages. Maybe the Neon's sender is mounted in such a spot, would explain the slow response.
As I stated before, I am hearing noises well after the light is out, indicating the oil hasn't reached the area where the noise is generated (probably valve train).
Harry
Harry,
Garageman,
I started using the 0w30 oil at 118,000 miles. I now have just over 210,000 miles. I started using the Eao shortly after they became available, I don't have the mileage figure, I'll have to look in my maint. record book. What I was saying is with the Honda filter, it took the oil light several seconds to go out, even with the 0w30 oil. Now with the Eao, it just blinks at me and the engine noise quiets at about the same time. I am sufficiently impressed to recommend this combination of oil and filter to anyone who'll listen.
Harry
Quote:
Quote:
...PC with ISO cleanliness level of 14/13/11. Further, this is the crème de le crème of results, since according to some here, you're the only person here qualified to produce such accurate results...
427Z06, I had a 14/13/11 on a 10k dino run with OEM Honda Filtech filter...
Code:
Particle Count
ISO Code (2) 14/10 clean
NAS 1638 Class 0
ISO Code (3) 14/13/11
>= 2 micron 252
>= 5 micron 93
>= 10 micron 25
>= 15 micron 10
>= 25 micron 2
>= 50 micron 0
>= 100 micron 0
10k dino UOA thread here
I didn't think anything of it, was that a good PC
Very impressive numbers. I think Hondas are easy on oil, they are so efficient, so I have heard, they don't produce a lot of particles anyway. Maybe explains why Honda engineers designed such a small filter.
Quote:
Garageman,
Harry
Harry,
Do you know exactly where the sender unit is mounted on your particular car? If it is mounted before the filter, a quick pressure buildup may indicate the filter is actually blocking the flow to some extent. The Honda filter let the oil flow through, and pressure didn't build up until the galleys were filled (in this particular scenario). But you say the noise disappeared at the same time, so maybe the sender is past the filter, and the Eao is flowing faster.
Location, location, location.........
Bob
Quote:
Quote:
Garageman,
Harry
Harry,
Bob
Bob,
Schmatically speaking, I don't know where exactly in the oil path the sending unit is located, it is physically just above the oil filter, so it's possible that is is after the filter.
Harry
Quote:
Bob,
Harry
Harry,
I think you're right, Harry. I just looked at my service manual, and it appears the sender is in the galley leading up to the head. It's quite impressive that just the filter change made such a difference. I may try this filter with my current fill of 5w30 Redline and note any change.
Thanks for the input,
-Bob
Quote:
Quote:
Bob,
Harry
Harry,
-Bob
Bob,
The Eao filter seems to be very "transparent" to oil flow, put a little in the filter before you onstall it, not enough to make a mess, watch the oil just disappear like there is nothing in the filter housing.
Harry
Quote:
Quote:
I don't know how much the MFT will be affected by the 0w30 as opposed to a 5w30.
Grades indicate little as far as gasoline economy. You need to be talking in terms of HTHS, FMs, and Kinematic Viscosities.
Quote:
I saw an increase when I went from a 10w30 to 5w30.
Good...then use the 5w30. But that has little to do with the filter.
Quote:
I appreciate the higher film strength in a synth. I don't think I would have trusted a 5w30 dino to replace a 10w30 dino.
What evidence do you have that the 5w30 synth your using has a higher film strength than another 10w30 dino? Further, please define "Film Strength" for me. What are the dimensions of "Film Strength"? I'll give you a hint...there aren't any. It's like saying it's "warm outside"...extremely vague and relative.
Quote:
Yes, I suppose changing more frequently would also keep clean oil in the crankcase, but why would you want to when this filter keeps it cleaner than new oil? Reference George's earlier posts in this thread regarding that issue.
As mentioned before, you hinging all your follow on logic based on ONE PC whose values are most likely extrapolated. It could be the case the pore blockage method used had a filtering particle size just below a critical level for the OEM filter and just above the Ea0 filter. This would skew all the data allowing a particular filter to look much better than it really is. I still contend we need more data under different circumstances before we start making blanket statements.
Quote:
The MPG savings would disappear in increased costs of more frequent OCs.
Not necessarily. If your train of logic contains a falsehood, the conclusion is likely faulty.
Quote:
It would seem that clean oil would be better than dirty oil, and the consensus here seems to be that the Eao keeps oil cleaner.
The only consensus I see here is a small group a people making unsubstantiated claims that this filter is second only to the next coming of a particular deity.
Quote:
The OEM filter in George's analysis allowed 100 and 50 micron particles to circulate. How long would a particle that size have to stay in the oil to start causing damage? What if it formed immediately after changing the oil? Then you would have to change oil every day.
I addressed this several times already. At this point I think you really need to study up on what various particle counts really entail. In short, your extrapolating from an extrapolation.
Quote:
I would just feel more comfortable with a filter that has shown superior cleaning ability.
Bob
Whatever floats your boat. But keep in mind that people will still question the cost benefit ratio as I don't see a wealth of evidence substantiating what you consider a forgone conclusion.
427,
First, let me preface by saying I am not affiliated in any way with Amsoil, Amway, or any other marketing campaign. I have nothing to gain from any statements I make here.
I pulled the term "film strength" out of my behind, because I didn't remember the actual term for the property that synth has inside a bearing. Under pressure inside a bearing, a 10w30 dino will have the characteristics of a 20 weight oil, if I recall what I read correctly. I have since found the term used in other articles describing what I was attempting to.
Scroll down to Part3 in this article, the term is used there.
http://www.volvoclub.org.uk/engine_oil_history.shtml
My theory (not proven, have no data to back up) is that the superior performance of synthetics allow the use of a lower viscosity, which will improve fuel mileage. You say it won't, by analysis, but in practice, it does.
The last paragraph of the second to last post here, also states this fact:
http://forums.noria.com/eve/forums/a/tpc/f/616604995/m/3781046331
I am not a professional oil analyst, in fact 95% of what I know about oil I have learned here (the other 5% from oil companies' advertising, so it may be "tweaked").
George's tests seemed to be accurate, and I had no reason to doubt them. I agree that extrapolating from a small measurement can be inaccurate, but sometimes that's all you have to go on. I have no reason to doubt your experience, either, I'll take all information and try to form a conclusion. Seems that for $20, you're not going to get an extremely accurate answer. I liken it to determining the number of grains of sand in a beach. You measure the amount in a ml, and multiply to get the estimate. If you measured from a part of the beach that had coarse grains, your final answer will be way off.
You're right, the filter doesn't really have anything to do with fuel mileage as far as we know, but TeeDub did say that "The improved filtration should also mitigate oxidative thickening over long OCI's and help maintain high fuel efficiency, much like a bypass filter setup." More frequent oil changes would probably accomplish the same thing, but with more hassle (maybe more expense, too). I'm trying to determine if one really is spending more money overall to experiment with different oils and filters. The Eao would be about $20 with tax and shipping (less if I joined their "club"). My K&Ns were about $10 ea. shipped. A cheapy filter is about $4 with tax. It wouldn't take much to make that up in savings at $3.25/gal for gasoline, IF it really does save fuel. If it doesn't, well, $16 toward my further education.
On the subject of VIIs being stripped out with finer filtration, bypass filtration systems filter down to 1 micron or less, and the virtues of bypass are touted everywhere, why hasn't this been an issue before?
-Bob
I'll leave the other stuff in the "
bin.
George's contention is that all other modality of bypass filters, regardless of claims, test results, published stuff (whatever) are not filtering to the 6um level. The process went like this (if I grasped it well enough).
Customer UOA showed signs of shearing/loss of visc
Conclusion: VII is stripped out a below 6um in filtration
Secondary Conclusion: All filters that claim any performance at, or below, the 6um range are not doing so. All of them.
This is hard to swallow. This was supported under the notion that you need 200 beta levels to claim absolute ..and that cellulose media has a broad variance in pore size. The problem with this is that even at Beta 20, 75, ??? ..if they were rated at researcher/testing data clearing house (SAE, whomever) would have surely encountered this in the past. If they have ..they've kept it very quiet.
Now no one says that there isn't some issue here. No one says that George is FOS ..but the conclusions drawn, in the face of tons of industry data over decades to the contrary. . seems to have escaped this condition/event .. surely has me wondering what else may have also been involved. I would surely like to find out just what it was that occurred in a definitive way
It's like having two men in a locked room and finding one of them dead ..and a gun with one spent round in the chamber 30 feet from the dead guy ..and next to the other. The living guy is the most likely suspect ..until you find out that he's in a body cast and can't move or use his hands. Just saying "He did it!!" leaves far more questions than it provides in answers.
Pointing to an internet article that uses the term "film strength" but yet does not define the term is kinda' meaningless. Synthetics may improve fuel mileage if many of their superior properties are taken advantage of, such as high VI and lower volatility at the same kinematic viscosity. If esters are included in the blend there may be some inherent Friction Modifying effects (coefficients of friction). But all of the above is not guaranteed. One could easily create a synthetic formula that doesn't increase fuel economy over a mineral oil based formula that does. GF-4 oils that are actually tested to verify they improve economy are built everyday with nothing more than Group II and Group II+ basestock. Read up on the GF-4 Sequence VIB test here:
http://www.swri.org/4org/d08/GasTests/VIBtest/default.htm
Guess what the ASTM BC oil is made of?
I don't see "film strength" used in that post.
Seriously, as stated above, synthetic formulas can be blended to improve fuel economy, but there's no guarantee that they will. That is why we need to measure the actual physical properties of the oil in question. These physical properties include but are not limited to Kinematic Viscosity, Viscosity Index, High Temperature High Shear, Coefficient of Friction, CCS, etc, etc.
Seems to be accurate? What does that mean? You have something to verify the accuracy of his numbers? Now I'll agree that George is probably an honorable person and fully intends to use all his abilities to produce the most accurate numbers he can. But this is still just one data point. In order to say anything with confidence I think other science minded people would agree we need more data points.
As mentioned earlier, we have to look at both significance and quantity. These filters may very well have improved filtration which mitigate oxidative thickening but by how much? And then how will that effect fuel economy in quantitative terms?
That's my question too. Only I referenced statements made by George where he stated that there are limits to how much you can filter motor oil because of the VIIs.
This post references that one of the "nine superior performance features of synthetic engine oils" is improved fuel economy. I only had one link to reference "film strength"
Thanks for including the link to swri.org, very informative. I noticed that fuel comsumption is measured by mass instead of volume. I think that's a flaw in most MPG claims. I can top off the tank, and the gas in the tank is already hot, so the incoming gas expands and I get an MPG reading of 70
Of course I keep a running total of miles and gals for an average reading.
It seems that particle count comparisons are only valid using the same vehicle in a controlled environment. What swri does is really controlled, right down to the flush on the fly, no skewed results from start-ups. George's engine I'm thinking is in a Crown Vic or Town Car, with a timing chain and hyd. lifters. Your Honda has a timing belt, and I'm thinking roller rocker arms, too. My 92 Civic has the D15B7 engine which does not have roller rockers, but the D15Z1 did. A whole lot less sliding oiled parts to produce particles.
You're absolutely right about more data points being needed, I didn't know test results for PCs could be extrapolated from ONE particle measurement. Blackstone says they screen for particle sizes greater than a specified size, and each smaller size test includes all of the larger size particles, at least that's how I read it. So the ratio will be mathematically close for each size range, simply because all the larger particles are included in the smaller size measurement, too. For instance, >2 um will also include >6, >25, >50, etc. If you have already established a 14:1 improvement of larger particles, the smaller particle measurements include all of the above, so it is starting off with a 14:1 ratio before including the particles in the 2-6 micron range. Am I making sense? Or you think this is way off base?
Yes, I agree more testing needs to be done, we are getting excited over one test, as much as I would over a 40MPG reading after putting 5 gals of cold gasoline in a 20 gal tank of hot gasoline........
Gary addressed the bypass filter stripping issue in the post before yours, thanks Gary. I'm wondering if the media in the Eao allows fine filtration in one area of its media, and less fine in others, allowing VIIs to pass. With enough passes, the smaller particles are bound to get caught, as they would in a bypass filter. Maybe that's why they recommend extended OCIs only when using their oil, which probably being full synth, has no VIIs?
Thanks for all the information,
-Bob
I just wanted to add that I switched from 5w30 Honda Genuine to 5w30 Redline with no improvement in fuel economy. Kinda deflated my balloon.
Harry is using 0w30 in his Honda, and he has noticed improvements in cold flow at startup. I have read that Redline is a "sticky" oil (I'm sure some others are too, I just don't know which ones), which I believe would reduce start-up wear. The oil galley drains in these cars, as evidenced by an empty oil filter after sitting for an hour.
Based on the lack of fuel efficiency improvement using the same grade of Redline, I'm thinking that switching to 0w30 will improve fuel mileage, while still affording adequate (if not superior) engine protection.
-Bob
Well, something occurred in George's installation of sub-6um filtration that evidenced itself in the loss of viscosity.
Normal reasoning would lead one to believe that the filter had something to do with it. The actual mechanism is undetermined and would be counter convention (to a very high degree) given the scope of explorations in filtration by icons in the industry like Parker and PALL (and others). One would reason ...with reasonable assurance (an assumption)..that someone ..somewhere ..would have put a warning out "Don't filter fluids with VII below 6um!!! VII may be removed!!". This is, in no way, to challenge the validity of George's assertions that this stripping occurred ..or at least something occurred that resulted in loss of viscosity. It merely raises some sensible objections ..stating, more or less, "How can this be so
Schultz, our fine product development engineer at PALL (and who has been a member of substantial value to the board with REAL testing capability), has offered to use his fancy membranes to filter VII laden oil down to (as low as) .25um. His cursory scan of this issue offered that a 6um molecule would be HUGE. He's tied up with a couple of product releases for a bit yet..so we're patiently waiting.
The full flow EaO doesn't filter that fine. I believe the media is rated at 15um absolute. Now the EaOBE filters are reported as being 2um absolute ..but they are, as you pointed out, unlikely to be used with conventional/dino oil. I wouldn't imagine that Amsoil would take for granted that they would not be used with conventional oil.
This is all good stuff here. This is what this board is about. Digging in and finding the truth about stuff. Information that is otherwise not available. Lots of people contribute time and resources. Not everyone agrees on the conclusions drawn ..but I cannot see that as a bad thing ..in anyway that I shake it up.
There you go. Just because an oil is made with synthetic components there is no guarantee that it will improve fuel economy in every engine and application. If one looks at some of RL's physical properties and the design of the engine in question, one can see why this may certainly be the case here.
Quote:
...I didn't know test results for PCs could be extrapolated from ONE particle measurement. Blackstone says they screen for particle sizes greater than a specified size, and each smaller size test includes all of the larger size particles, at least that's how I read it. So the ratio will be mathematically close for each size range, simply because all the larger particles are included in the smaller size measurement, too. For instance, >2 um will also include >6, >25, >50, etc. If you have already established a 14:1 improvement of larger particles, the smaller particle measurements include all of the above, so it is starting off with a 14:1 ratio before including the particles in the 2-6 micron range. Am I making sense? Or you think this is way off base?
I can't follow your mathematical procedures. In any event, Gary has some insider info on the Blackstone PC process and IIRC, it's nothing like you describe here.
Blackstone describes the particle count test here:
http://www.blackstone-labs.com/all_about_particle_counts.html
In the sample chart, they count >2, >5, >10, >15, >25, >50, >100 micron size particles. My contention is that the figure for >50 includes the >100 count also. It follows that the >25 count includes the count for >50 & >100 figures, etc., etc. In their sample, the >2 count is 661. Included in this is the 244 figure from the >5 count.
If you compare results line by line, the >2 figure is 37% >5. If you have already established a 14:1 ratio between two measurements of the >5 count, then 37% of the >2 count already is 14:1. The 2-5 micron range would have to be extremely different to effect a change in ratio.
George's tests were:
Quote:
OEM oil filter PC vs. Amsoil EaO57 Oil filter PC
>4 Microns = 1,817 particles, 128 particles
>6 microns = 990 particles, 70 particles
>14 microns = 168 particles, 12 particles
>25 microns = 34 particles, 2 particles
>50 microns = 3 particles, 0 particles
>100 microns = 0 particles, 0 particles
You state that:
1817/128= 14.20
990/70= 14.14
168/12= 14.0
34/2= 17.0
indicates extrapolation.
My contention is that if you subtract each figure to get the PC in each range, you get a different ratio:
OEM filter / Eao filter
4-6 micron range: 827 / 58 = 14.26
6-14 micron range: 822 / 58 = 14.17
14-25micron range: 134 / 10 = 13.40
25-50micron range: 31 / 2 = 15.50
Still seems close, doesn't it? But not as close as you contend....
Just my
-Bob
Quote:
You state that:
1817/128= 14.20
990/70= 14.14
168/12= 14.0
34/2= 17.0
Just my
-Bob
Actually, it looks like you proved my point better than I did.
Seriously, I just find it strange for two differently constructed filters to have nearly the same ratios among the particle sizes. I might be totally off base here, but I would expect some kind of knee in the curve at the smallest pore size as the filtering transitions from a straining to impingement, interception, and diffusion filtering mechanisms.
Quote:
Quote:
You state that:
1817/128= 14.20
990/70= 14.14
168/12= 14.0
34/2= 17.0
Just my
-Bob
Right, if the truth is there, it will be borne out no matter how you look at it.
Besides, George's new thread explains the pore blockage measurement method. The screen used is a 10 um, so the other values are arrived at using extrapolation with established patterns. As I stated there, a truly remarkable filter would not follow established patterns, and the extrapolated figures would be meaningless.....
-Bob
