Are there any safe seal and gasket conditioners additives out there? I have some non high mileage oil I want to use up, is there any additive out there that will effectively make a non high mileage oil a high mileage oil?
There are seal swelling esters that will make a dry hard elastomer soft again and will swell in size. "dry" oils will over time casue seal shrinkage and drying out so it will NOT follow the crankshaft or whatever any more allowing leaks a quality PCMO will acount for this.
But in no case do these additives "fix" anything or even "condition" ( insert word of choice here) the seal material.
Don't these seals degrade due to heat cycles and age?
What happens if you use a motor oil like Red Line that is mostly made of PAO?
Yes they degrade with heat cycles and age, a fact of life. The short answer is the oil you mentioned "may" help, and it "may" not help. Bottom line is nothing lasts forever, and a lot of money can be wasted trying to make something that wasn't designed to last forever, last forever. A good oil and a good maintenance schedule will help to extend engine life, how long? No one knows for sure.Don't these seals degrade due to heat cycles and age?
A separate consideration is the mechanical properties of the seal such as shaft fit, abrasive wear at the contact surface, surface finish, contact geometry and garter tension.
so, depending on a host of variables the naked eye cannot detect, identify or discern,- just dumping a new chemical in there that may cause a temporary reaction and shrink/swell a part of a seal can have unknown and undesirable consequences in both shot and long term usage.
Since the most benefit comes from viscosity making it leak through the holes less- just bump up the grade and be done with it.
Along with this, if seals and gaskets are worn and leaky, does a conventional, synthetic blend, or full synthetic make a difference in terms of how much leaks out?
@ABN_CBT_ENGR , this is somewhat of an off-topic question.
Is seal compatibility still a significant issue with differential oils? When GM first launched Dexron-LS gear oil, they required for the axle seals to be replaced prior to using the new oil due to a seal compatibility issue.
https://static.nhtsa.gov/odi/tsbs/2014/SB-10069269-9133.pdf
I always thought that seal compatibility (with oil), especially for gear oils, is a non-issue these days. Thoughts?
Thanks. In other words, it is generally a non-issue due to standardized seal compatibility test and materials, but there are always "one-off" situations....and that TSB may be an example.My best answer is... ( this has come up before and i have had numerous conferences with both seal and oil OEMs over the years and the answers are consistent)
In industry, there is no such thing as taking seal compatibility for granted because of the lubricant, process chemicals, etc. ( whole different animal)
Its my understanding from what little fleet stuff I do that in the automotive world there are standard seal materials and they are tested for compatibility with the major standards and as such its not a consideration these days. I tend to believe that is correct because nobody hears of incidents where oil "X" has a reputation for killing seals.
I do know of some situations outside of that standard but those are still industrial applications and not a concern for the average car owner.
I would think so and a "one off" could be on either side of the sealThanks. In other words, it is generally a non-issue due to standardized seal compatibility test and materials, but there are always "one-off" situations....and that TSB may be an example.
