Some of the Seafoam will get into the crankcase. However, don't sweat it. After you pour the stuff in and let it sit, remember to do it when engine is warm, run it at regular temperature for about 20 minutes. Seafoam uses distilled products which will burn off like fuel does in the crankcase. It just takes a few minutes. Also, you have to run the engines to blow out all the carbon that loosened up from using Seafoam. Best to hit it with a couple of WOT runs.
