Any problems are not relevant to the work you did or the Seafoam, unless you knocked something else loose in the process.
Oil change won't help.
Sorry, but it looks like the computer may have gone South. You'll need a pro with the scan tool to determine. Since you decided to use Seafoam and change plugs, it must have be running not so good, so this was a pre-cursor to failure. I'd vote for electronic failure and may have be intermittent.
