Schaeffers Supreme 9000 5w-30, Ford F150 2.7 Ecoboost
Here is my latest UOA from my 2015 F150 with the 2.7 Ecoboost. I ran this oil a bit longer than I planned to, about 5900 miles. I took a long trip right before the oil change which put me over the 5000 I was planning on. Looks like a good report, except the Viscosity was a bit lower than the previous run. The oil life monitor was at about 40%, on track for a 10,000 mile interval. It sure seems like that would be way too long for this motor. I recently started using the truck for work, pulling an enclosed trailer at around 5000 lbs. I might go 5000 miles on this oil change, put the Schaeffers back in it.
I'm always impressed by these 2.7s, fantastic little mills. A great looking report too, 7500 should be easily possible if you wanted.
Looks like a good report. Thanks for posting. I have a 2016 F150 with the same engine and same oil. My first run with Schaeffers. Hopefully mine will look this good.
How long are you planning on running it? I really like this oil so far, but this last run took the viscosity close to being out of the 30wt range, probably won't go quite as long this time.
I'm a little hesitant to go much further than this last run, afraid the viscosity will end up being quite low. Maybe It's not that big of a concern? I do really like this engine, impressive so far given it's size.
I was planning on 7,500 but might cut it back since since this is the first run.
