If you did a used oil analysis with 132 in your oil would the antimony show up as the wear metal lead ? IE if the lab didnt know it was there would they think that the wear lead was higher than normal ?
If you stay at or below 50 mL of #132/Quart of Oil, then your vis won't go out of grade.quote:
EDIT: One more thing.....to those who might want to use it, do not be scared by the high viscosity. I added 350ml to 1 qt of Mobil 1 15W-50 and ~4.5qts of Mobil 1 10w30 and the UOA still show in the 30W range. Once you mix this stuff in oil, it dilutes very well.
Thanks MolaKule,quote:
Originally posted by MolaKule:
RB,
132 has a different type of ester.
Calvin,
Antimony is the element Sb, lead is the element Pb, and tin is the element Sn. If the analysis guy has any chemistry education at all, there is no way the antimony could be mistaken for lead.quote:
Using #132 with Mobil 1 5w30 I noticed very little viscosity increase. Mixing it with Pennzoil Conventional 5w30 OTOH and the viscosity change was much larger. Does this make sense?quote:
Reagrding the name for#132:
Look at this way, if they called it Antimony EP do you think anyone would know what the heck the product was about?
Last_Z;
As Last_Z said, it has an amazing set of base fluids; it comes out at 2500 cSt and is miscible with any oil without unduly raising viscosity, if not overtreated.
I'm assuming the samples you tested were used oil analysis. If so, maybe the dino oxidized much more than Mobil 1, which in turn, combined with the #132 went off the chart.quote:
Last_Z;
ferb, Lubro Moly is the company's name. They do not use moly in all their products. When they started out, moly was probably their "big thing" in their greases and lubes. In fact they still sell plenty lubes with moly, but moly not in their motor oil, which is not their main product anyway. They do however sell a popular moly oil treatment.quote:
Ferb
Member
Member # 483
Icon 1 posted March 01, 2004 06:37 PMMarch 01, 2004 06:37 PM Profile for Ferb Send New Private Message Edit/Delete Post Reply With Quote
quote:Originally posted by dagmando:
Moly of 32 for a product that advertises a Moly treatment, very lame.
The brand name "Lubro-Moly" always made me laugh since it has no moly in the two VOAs on the board. It may lubro, but it sure doesn't moly.
ferb!
Hey Mola,quote:
No adverse effects other than viscosity increase with higher treatment rates.quote:
Mola, Just out of curiosity......you recommend using this stuff at 50ml per qt. Is there any adverse effects if you overtreat by say 10-20ml, besides a viscosity change? Thanks
if you want a moly oil thickener, check out valvoline maxlife engine protector. I know it's blasphemy to mention valvoline on this boardquote:
All the tought about product and this is what it is?! It an oil thickener, that's it. Moly of 32 for a product that advertises a Moly treatment, very lame. You would better of using STP oil treatment for $2 and your local parts store. If you do just want to thicken up the oil, add a quart of xW-50/40 for $1.
