I stated this on my used oil analysis post in that section, but thought it was worth repeating here -
The Schaeffer PDSs show a fairly broad range for 40deg and 100deg viscosities (they don't give a pt estimate like other manufacturers). And their ranges for their 5w30 products are rather low numbers on the bottom side of the ranges.
My used oil analysis confirmed this - the Schaeffer 9000 5w30 had significantly lower viscosity (after 4k miles) than the Pennz. Plat. 5w20 had at 5.4k. No fuel dilution issues.
The Schaeffer 5w30 used oil analysis #s -
SUS Visc. 210degF - 52.1
cST Visc. 100degC - 7.9
The Pennz. Plat. 5w20 #'s -
SUS Visc. 210degF - 54.5
cST Visc. 100degC - 8.61
One of the (several) things that attracted me to using Schaeffers was this low visc. - at that time this van was a short tripper. But coming in below a 5w20. (?)
Note that the Schaeffer 7000 5w30 PDS shows -
40degC Visc - 47 to 52 (is that not edging into 5w20 territory?)
