Patman
Staff member
Here are my latest oil analysis results on my car, done by Wearcheck
Mississauga (also with interpretation to be done by Terry Dyson). I've
included the 740 mile baseline sample on the oil, and the final result
at 4400 miles to see how the oil fared over the interval. This is my second
interval with BobZoil (Schaeffer Supreme).
Here is the data:
1995 Firebird Formula
350ci LT1 engine, 275hp (unmodified), automatic trans
10w30 Schaeffer Supreme 7000 blend (SL formulation)
4400 miles on oil/81,000 miles on engine
3oz Auto-rx maintenance dose
K&N oil filter (oversize HP3002)
OEM AC Delco air filter
Oil was run from Dec 7 to Mar 16 (14 weeks)
Average of 314 miles per week
Top up oil was 1 quart (most of which was added right after the 740 mile
sample)
Oil capacity is 5.3 qts
This is my daily driver, with lots of rush hour highway traffic, and not
much full throttle driving on this interval (due to winter weather)
Car rarely sees short trips except on the weekends where it's started
stone cold once each day and moved from visitors parking back to my driveway, total running time of about 60 seconds each time
Extremely cold winter weather (most mornings below 10F, some mornings as low as -10F and car is always parked outside) and quite a lot of idling this interval (due to some very
bad traffic and a visit to the dealer for a new water pump)
As you can see, winter weather just kills an oil! The lab did tell me to change the oil if I had not done so already (due to the TBN). It was interesting to see that the viscosity at 100c didn't change much (especially with 1% fuel in it) but that the viscosity at 40c changed. This oil wouldn't have flowed nearly as well in the extreme cold at the end as it did when new. The coldest temps of our winter were in the last few weeks too.
They use a lot of road salt here, and I think that shows in the results too.
I am currently running an 1800km (1100 miles) interval with Auto-rx and
10w30 Schaeffer Supreme (and an AC Delco PF1218 filter), and then will
be running an 8,000km (5000 miles) interval with the same plus a 3oz maintenance dose of rx and a Carquest premium oil filter (same as NAPA
Gold). I expect this next interval to show drastically different results. Winter weather is definitely not easy on the oil, like I predicted at the beginning of this interval.
[ October 08, 2003, 06:21 AM: Message edited by: Patman ]
Here is the data:
sample)
note: this lab's TBN is lower (D-4739 scale).code:
740 miles 4400 miles
Iron 10 25
Lead 3.5 7.8
Aluminum 3.9 6.2
Copper 1.5 3.3
Silicon 8.1 12
Nickel 0 0.1
Chromium 0.5 1.3
Titanium 0.3 0.2
Tin 0 0.6
Silver 0.4 0.3
Vanadium 0.3 0.2
Potassium 0.2 0.3
Sodium 2.7 26
Boron 3.0 4.0
Barium 0.5 0.4
Manganese 82 222
Calcium 1830 1670
Magnesium 19 29
Moly 102 97
Phosphorus 857 765
Zinc 967 927
Sulfur 2773 2698
Fuel 0% 1.0%
Glycol 0% 0%
Water 0% 0%
Sulfation 42% 60%
Oxidation 37% 51%
Nitration 15% 39%
VI 150 129
Vis @ 40c 60.9 69.4
Vis @ 100c 10.0 10.1
TBN 5.23 2.90
