Here is the one from Autel for $150 with domestic ABS and airbag capability. Mind you that reviews are mixed and I returned my Japanese version because it had few bugs. The same Amazon return privileges apply, so your risk is minimal.
The Autel MaxiDiag US703 is an innovative multifunctional scan tool created for technicians who need a single tool suitable for both the general troubleshooting of Diagnostic Trouble Codes (DTCs) on OBD-II/EOBD compliant vehicles, and more focused work on GM, Ford and Chrysler vehicles. Powered by Autel Uni-SCAN technology, the US703 supports all current OBD-II/EOBD protocols, including CAN (Controller Area Network), and provides engine, transmission, ABS and airbag systems code support for GM models 1984-2006, Ford 1984-2006 and Chrysler 1988-2006. OBD-II is the second generation of an onboard diagnostics standard for cars and trucks and has been a mandatory requirement for all vehicles sold in the US since 1996, both domestic and imports EOBD is its European counterpart, required on gasoline models since 2000 and diesel models since 2003.
Along with its compatibility with a variety of makes and models, stretching back to 1984, the US703 also adds additional flexibility to any mechanic's tool box with its wealth of built-in features. These include the ability to retrieve generic and manufacturer-specific codes, a built-in OBD-II DTC lookup library that is updatable via the Internet, O₂ sensor data and live datastream parameters, data graphing (1996 models and newer), memory/battery backup for off-vehicle data review and analysis, trilingual support (English, Spanish, French), the ability to print data via PC, and more.
Complete Features:
* Troubleshoots engine, ABS, transmission and airbags codes
* Global OBD-II/EOBD coverage (US, Asian & European)
* Powered by Uni-SCAN technology with no adapters to buy
* Supports all nine test modes of the latest J1979 OBD-II test specs
* Retrieves generic (P0, P2, P3, and U0) and manufacturer specific (P1, P3, and U1) codes
* Displays DTC definitions on unit screen
* Views freeze frame data
* Displays O₂ sensor data as well as live datastream parameters
* Data graphing – (1996 and newer)
* Reads, stores and plays back live sensor data
* Memory/battery backup for off-vehicle data review and analysis
* Performs modules present test
* Retrieves vehicle information (VIN, CIN and CVN)
* Supports all current OBD-II protocols, including CAN (Controller Area Network)
* Extremely easy to use and highly reliable
* Trilingual support—English, Spanish, French or other combinations
* Software upgradeable via Internet
* Built-in OBD-II DTC lookup library
* Prints data via PC
Product Description
Powered by Autel Uni-SCAN technology, the MaxiDiag an innovative multi-functional scan tool designed for technicians to troubleshoot engine, transmission, ABS and airbag systems for most of the vehicles. Reliable, easy-to-use and affordable, the scan tool is a time saver and a money maker. It supports all nine test modes of the latest J1979 OBD II test specs and retrieves generic as well as manufacturer specific codes. This scanner retrieves vehicle information, performs modules present test, views freeze frame data and displays O2 sensor data as well as live data stream parameters. It comes with built-in OBD-II DTC lookup library and is software upgradeable via internet. This scanner reads, stores as well as playbacks live sensor data and prints data via PC.
