Looking for a relatively inexpensive scan tool that can read transmission temp
HYPER TOUGH HT500 ( INNOVA ) at WALMART for $49.98 . Use it with Bluetooth . Helped solve issue with the FIT . Many YouTube videos for reviews and instructions . Here's the post with pictures .
HyperTough HT500 Bluetooth scanning tool for $49.98
Plan to use it when driving . Checked tires with HyperTough digital tire gauge and 1 tire was 35 and 3 were @ 34.8 .bobistheoilguy.com
It depends on what module in each vehicle displays the Transmission temp and what modules this scanner is able to access on each vehicle. Most cheap scanners cannot access all of the modules on these modern vehicles. They usually only access the ECM, ABS, and SRS and that is it. If the transmission temperature is displayed in the TCM module on the 13 Fit and this scanner cannot access that module then you will not see a PID for it. Maybe the Hyundai has this information in the ECM.There's a picture in the link above showing the A.T.F. temp of 141.8 for the '18 HYUNDAI Accent . Can't get it to read the '13 Fit A.T.F. temperature . Why ?
