Originally Posted By: bullwinkle
Originally Posted By: goodtimes
Even if your filter media is plugged solid you shouldn't have "hard knocking", you know that I'm sure. Oil should still flow plenty. Too thick oil, or failed adbv? I am glad you said what appeared to be pressurized oil, because I doubt it was, like you say, how can you explain that one.
I can-media was plugged, ADBV was holding pressure in between the media & the can.
You must envision pressure sealing oil pumps and rubber adbv's. I doubt that, and that the oil filter was plugged solid, which wouldn't matter anyway IMO. Oil pumps have clearance and the galleries are rigid, the pressure is going to go down right away. I would say it is a dose of imagination, something against E10, and a bunch of oil coming out of an oil filter by gravity. All the gas I have used for years has been with ethanol and no filter was plugged by it. Maybe a little frank, but that is how I see it.
