Safety Kleen pds
Ive used their 15w40 for everything from HMMWV Oil to Tank Drive Sprocket (Technically transmission) fluid,
If it can come out as clear as it did after about 900 Miles in the transmission of a tank and no sleep in the Fort Irwin Deserts, id use it.
Needless to say, it is Recycled oil, which is a turn off for some
Originally Posted By: Gumby
...Needless to say, it is Recycled oil, which is a turn off for some
I don't think it is "recycled" oil.
It is more properly defined as, "re-refined" oil.
It is a mixture of re-refined oils (GroupII) and other GroupII and GroupIII oils.
The three oils below are GTL GroupIII:
178603-64-0 Gas oils, petroleum, vacuum, hydrocracked, hydroisomerized, hydrogenated,
C15-30, branched and cyclic, high viscosity index
0-45
178603-65-1 Gas oils, petroleum, vacuum, hydrocracked, hydroisomerized, hydrogenated,
C20-40, branched and cyclic, high viscosity index
0-45
178603-66-2 Gas oils, petroleum, vacuum, hydrocracked, hydroisomerized, hydrogenated,
C25-55, branched and cyclic, high viscosity index
0-45
Molakule is right about that. Molakule: thanks for the info and your insight
