Safe to mix Dexcool and Amsoil low tox coolant?
I have an 06 Saturn Ion Redline. It's supercharger intake air is liquid cooled and it's been using coolant lately because the laminova core seals are leaking.
I have run out of the Dexcool I usually put in, but I have a jug of Amsoil Low Tox. It says on the jug that it mixes with everything,
this is true for Dex as well?
(I will be rebuilding the intercooler system soon, afterward will be switching over to Amsoil Lox Tox)
Thanks!
Low Tox coolant is proyplene glycol. Walmart has a propylene glycol coolant called Peak Ecoshield.
Don't mix Deathcool with anything except Deathcool and other Dexclones. The cheapest universal coolants are Deathclones, so if you're leaking coolant, just use the cheapest coolant like the $5 Prestone from Dollar Tree.
Don't waste expensive Amsoil coolant on a leaky system :sneaky:
