Originally Posted By: The Critic
So far, I've come to the conclusion that it is possible to blend a product that satisfies the oxidation, corrosion, load carrying capability and shear stability requirements, but I'm not convinced that one product can truly satisfy the OEM frictional requirements of every application. Granted, as Whitewolf mentioned earlier, it's possible for some transmission to be more forgiving than others, thus frictional characteristics that deviate slightly from the approved service fill may not cause long-term damage.
That makes some intuitive sense to me. I'm pretty sure the OEM friction requirements are specified by giving both an optimal value and an acceptable range around that value (as opposed to only specifying a minimum or maximum acceptable value). While each particular ATF spec likely has a unique optimal value, it seems certain that there is considerable overlap amongst their accpetable ranges.
My guess is that multi-spec ATF's work by exploiting this overlap by having friction properties that while perhaps near optimal for only a few standards are within the acceptable range for many. The difference in spec listing amnong the various multi-spec ATF's is due to different choices on where to thread the properties through the various ranges.
Which brings to mind the old Russian saying of "'Better than' is the enemy of 'good enough'."
