SAE 90 Gear Oil
I have a older garden tractor (Wheel Horse) that has a gear drive transmission. The manual calls for a straight SAE 90 (GL-5). I have done a lot of searching and it is very difficult to find. If I went with the standard gear oils (85w-140 or 80w-90 or 75w-110), GL-5, which alternative would you use? What would be the downside to not staying with the SAE 90?
Can you find out which sae90 oil was recommended exactly? sae 90 has been split into sae90 and sae110 in recent years, so if they recommended a thick sae90 you could consider sae110 and be in spec.
Here is the gear oil spec from the manual. In some of Wheel Horse's older tractors (but basically the same transmission), they use to recommend 90-140 GL-5. Not sure what caused them to change to the SAE 90.
Believe it or not, my '08 Sorento specifies straight 90W GL-5 oil. I called the local Kia dealership about this...they knew nothing of it (of course), and said to use 75w-90.
Although not available in my local area, it is **** near unobtainium...overseas.
