Try this I put the Ford one below. Though I don't know what engine. I will assume diesel. Looks like synthetic is required for the rear diffs, but not the front. You need to read between the lines. The OEs want you to be confused and buy their overpriced gear lubes. Good luck.
http://www.amsoil.com/mygarage/vehiclelookup.aspx
2006 FORD TRUCKS F350 PICKUP 6.0L 8-cyl Engine Code [P] Turbo Diesel
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......CI-4+
SAE 15w40 Synthetic Heavy Duty Diesel and Marine Motor Oil (AMEQT)
Synthetic 15w40 Diesel Oil (DMEQT)
Synthetic 15W40 OE Diesel Oil (OEDQT)
-9 To 90 F......10W-30 [1]
-20 To 30 F......5w30, 5W-40 [2]
-20 To 0 F......0W-30 [2]
above 10 F......15W-40 [3]
Manual Transmission,S6-650 (6-SPD)......MA
All TEMPS......
Synthetic Multi-Vehicle Automatic Transmission Fluid (ATFQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Automatic Transmission,5R110W......MSP
Low Viscosity Synthetic ATF (ATLQT)
Standard Differential, Rear Ford 10.5 RG......GL-5
All TEMPS......75W-140 [4]
SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
80W-140 Synthetic Long Life Gear Lube (FGO05)
Limited Slip Differential, Rear Ford 10.5 RG......GL-5*
All TEMPS......75W-140 [4] [5]
Standard Differential, Rear Dana 80......GL-5
All TEMPS......75W-90 [4]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Standard Differential, Rear Dana S110......GL-5
Standard Differential, Rear Dana 135......GL-5
Limited Slip Differential, Rear Dana 135......GL-5*
Standard Differential, Rear Dana S130......GL-5
Differential, Front Dana 60......GL-5
All TEMPS......90
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Limited Slip Differential, Rear Dana 80......GL-5*
All TEMPS......75W-90 [4] [5]
Transfer Case,......MA
Fluids
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......
No AMSOIL Product Recommendation
Power Steering Fluid......MA
Clutch Fluid......HB
[1] Ford TSB 05-16-6 states that SAE 10w30 is acceptable
to use in operating temperatures from -1 °C (31 °F) to
32 °C (90 °F).SAE 10w30 is the preferred viscosity if the
operating varies from -20 °C (-4 °F) to -1 °C (31 °F).
[2] Ford TSB 05-16-6 states that the shown viscosity is
acceptable to use in the shown temperature range.
[3] Ford TSB 05-16-6 states that SAE 15w40 is acceptable
to use in operating temperatures from -12 °C (11 °F) to
-1 °C (31 °F). SAE 15w40 is the preferred viscosity if the
operating is above -1 °C (31 °F).
[4] Synthetic oil is required.
[5] Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or
equivalent formulated to meet Ford Spec EST-M2C118-A
for complete refill of limited slip axles.
FILTERS:
Oil Filter Absolute Efficiency Oil Filter (EA15K88)
Oil Filter AMSOIL Ford 6 L Oil Filter (SDF88) [1]
Oil Filter P550528 Oil Filter [1]
Air Filter P603577 Power Core Air Filter [2]
Air Filter P603577 Power Core Air Filter [3]
Air Filter WIX 49490 Air Filter [4]
Fuel Filter Fuel Filter for Ford 6.0L Diesel Powerstroke Applications (FFK60) [5]
Fuel Filter WIX 33899 Fuel Filter [5]
Transmission Filter WIX 58624 Auto Tran Filter [6]
Transmission Filter WIX 57702 Auto Tran Filter [7]
[1] Has No Lid Attached to Filter
[2] Standard Powercore Version
[3] Standard Powercore Version
[4] Replacement element for 24490 housing.
[5] Two Elements per box
[6] 5R110W
[7] Bypass Element
NGK PLUGS AND WIRESETS:
No Recommendations
WIPER BLADES:
Blade Class Driver Passenger
ExactFit T201 T201
NeoForm T16200 T16200
Winter T37205 T37205
CHASSIS LUBRICATION:
4WD
0-7 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Synthetic Multi Purpose #2 (GLC3P)
Synthetic Water Resistant #2 (GWR3P)
2WD
4-10 Fittings, 0 Plugs..........LM
CAPACITIES:
Engine, with filter..........15 quarts [1]
Cooling System, Initial Fill..........27.5 quarts [2]
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 5R110W Initial Fill..........7.5 quarts
Automatic Transmission, Total Fill
5 speed 5R110W..........19 quarts
Manual Transmission, S6-650 (6-SPD)..........11.6 pints [3]
Manual Transmission, S6-650 (6-SPD)..........12.7 pints [4]
Differential, Dana 60 Front..........5.9 pints
Differential, Dana 80 Rear..........8.5 pints
Differential, Ford 10.5 RingGear Rear..........7 pints
Differential, Dana 135 Rear..........23.2 pints
Differential, Dana S110 Rear..........16.1 pints
Differential, Dana S130 Rear..........16.1 pints
Transfer Case, ..........4 pints
[1] When refilling, remove dipstick to provide adequate venting
and allow oil to flow into crankcase.
[2] Includes heater and 5.0 qt (4.7L) in coolant recovery
[3] Without oil cooler
[4] With oil cooler
TORQUES:
Oil Drain Plug.....32 ft/lbs
Manual Transmission ZF S6-650
Fill Plug 26 ft/lbs
Drain Plug 26 ft/lbs
