Hi guys. Newbie here. Learned so much from the engine oil forums but I'm less knowledgeable on gear oils so I have a few questions.
The gear oils in my Toyota Fortuner (Mid-size SUV. I think only available in Asia and Aussie) is due for change in a few weeks. The manual specifies the following gear oils:
Transfer case - 75W-90 API GL-5
Front Diff- 75W-90 API GL-5
Rear Diff - Hypoid gear oil 90 API GL-5
1. Most of the oils I see are 80W-90. I shouldn't have any problems using them, right?
2. I have not found any monograde 90 gear oil for the rear diff yet. Is it ok to use the 80W-90 on it?
3. Do all GL-5 rated gear oils automatically qualify as EP or good for use on hypoid gears?
