Long story short I just bought a Quick36 mower and the crank is filled with 30 weight. Saved around $500 buying this time of year - figured it was worth it. Engine has .2 hours on the meter. It has the Kawasaki 16 hp v-twin with a spin on filter. I'm having a tough time resisting NOT firing it up and riding around on the step-saver. It's cold here mid 20's Fahrenheit
So . . . I want to dump the 30 weight in favor of a 5w30 or Rotella T Synthetic 5w40 for better cold flow and less start up wear. Yes the manual says the thin oils are ok for cold temps.
I have the following oils in the garage:
Valvoline Syn power 10w30
Valvoline standard 5w30 conventional
Super Tech 5w30 conventional
Pennzoil Platinum 5w30 Synthetic
Valvoline Maxlife Full Synthetic 5w30
Valvoline Maxlife Regular Flavor 5w30
Mobil 1 10w30 High Mileage "the good stuff"
Mobil 1 5w30 T & SUV
Shell Rotella Syn 5w-40
What would you use in the Kawi?
