I decided to give a bit of a facelift to one of my S&W 5946's with a new set of Turkish Walnut grips from Tactical Makgrips. These are one piece grips, (glued and finished as one), that are very nicely manufactured. They give you a new steel mainspring housing cap that installs into a "pocket" that's machined into the grips. This allows them to fit without screws, much like the factory plastic grips, and be retained with the original mainspring retention pin.
Installation was pretty straightforward. Simply remove the old grips by driving out the retaining pin with a 1/8" BRASS punch. Then carefully massage the new one piece grips into position by pushing upward and forward, while rocking them back in forth to allow all the cutouts to line up with everything.
The last 1/4" or so is the toughest, because you are fighting the tension of the mainspring, while getting the holes in the grip to line up properly with the new mainspring housing that is provided with the grips. Then press the pin in with finger pressure to get it started, then tap it back into place.
They feel good, and look a lot better than the factory plastic grips. The checkering is nice, but not overly aggressive. And the gun feels good in the hand. If anyone has one of these 5900 series pistols, it's a nice and easy way to dress them up a bit. I can't decide what to do with the other one. I might try a set of Hogue smooth Pau Ferro grips to see how they look. Or else go with another set of these.
www.tacticalmakgrips.com
![www.tacticalmakgrips.com](http://www.tacticalmakgrips.com/cdn/shop/products/13_a75e38ab-18f2-4c86-9423-d3b51f503f9c_1200x630.jpg?v=1652692384)
Smith Wesson S&W 4046 TSW,5903,5903 SSV,5904,5906,5943,5944,5946,5967 Gold Metal Grips
* Simith Wesson 5906 Wood Grips, Magazine, Hard Wood Grips,* Walnut Wood Grips.* Fully compatible with your gun* Does not adapt to forged and handcrafted weapons* High Qualty Hardness Walnut Wood* Cool And Swanky *Compatible Models : 411 - 910 - 915 - 5903 - 5904 - 5906 - 5943 - 5944 - 5946 -...
![www.tacticalmakgrips.com](https://www.tacticalmakgrips.com/cdn/shop/files/logo1_32x32.png?v=1631709469)
![JkCUO6Y.jpg](https://i.imgur.com/JkCUO6Y.jpg?3)
