RX-5 fifth oil sample
Auburn, CA
2004 Mazda RX-8
Oil OEM Redline Redline Redline Redline
5w20 5w20 5w20 5w20 5w20
Oil added 0 0 0 0 0
Miles on Oil 1250 1764 1500 1500 3000
Miles on Unit 1250 3014 4520 6067 9166
Date 12-13-03 12-30-03 02-09-04 03-24-04 06-04-04
Aluminum 9 5 5 10 6
Chromium 4 5 6 5 6
Iron 30 30 33 29 29
Copper 18 22 15 10 7
Lead 1 2 0 3 3
Tin 0 1 4 0 1
Moly 480 471 578 599 586
Nickel 1 1 1 1 1
Manganese 0 1 1 1 0
Silver 0 0 0 0 0
Titanium 0 0 0 0 0
Potassium 0 2 5 4 3
Boron 137 71 37 24 17
Silicon 42 28 21 17 15
Sodium 8 15 18 20 20
Calcium 1724 2421 2565 2841 2906
Magnesium 5 6 7 6 6
Phosphorous 850 1015 1084 1077 1091
Zinc 884 1236 1165 1236 1362
Barium 1 1 0 0 0
SUS Vis@210C 50.3 50.9 53.4 54.1 54.4
Flashpoint F 335 325 340 370 395
Fuel 1.5% 1.5% 1.3% .5 .5
Antifreeze 0 0 0 0 0
Water 0.0 0.0 0.0 0.0 0.0
Insolubles 0.2 0.3 0.4 0.4 0.3
I guess this report was missed. (June 14th? ) Fe is consistantly high. Break in probably.
Seems like a waste of $8/qt oil. Would a $4 or $2/qt oil do the same?
Doesn't it seem like you would still have the same Fe levels if it were just broken in with some petro oil using 3, 3k intervals
Interesting none the less.
Originally posted by Al:
Why are you changing so often??
He probably does it due to the fact that when you drain the oil in an RX-8 you only get about half of the oil out, the rest of it gets trapped in the oil cooler lines.
I would try Motorcraft 5w-20 or Mobil 1 0w-20 just for kicks. If the longest your going to extend OCI is 3k or 4k miles then Motorcraft would probably work great. I have a feeling that either oil would give better numbers than Redline.
