Dexter, Lipper are often recommending to lube the axle bearing at least once a year. Some are doing that through the easy lub zerks I personally think its ridiculous. Too much grease is not better that not enough ... to much grease can cause overheating
I do it every 3 to 4 years , I put 10000 km per years and I believe its more that sufficient.
I was using Lucas Xtra polyurea before but its not available anymore so Ill go with a synthetic grade 2 GC-LB
I am curious to know what is you repacking schedule and how you do it ... personnaly , I remove everything, wash everything, start with new grease , new seal pack the bearing, put a bit in the hub and the caps and thats it ... so far its working for me
