Originally Posted By: JHZR2
Originally Posted By: Cujet
Nice job!
There are products that work very well to stop corrosion. All of them are oil based.
LPS-3 dries to a waxy coating and is thin enough to penetrate a little bit, during application
AV-30 dries to a tough waxy coating and is very thin during application, it is engineered to wick into tight areas. It's the best, by far, of any of the "wick and protect" products I've found. It prevents corrosion, 100% when applied correctly.
Par-Al-Ketone is a cosmoline type product. It's cheap, easy to apply, and easily thinned with MEK to make it wick. It also dries to a semi hard coating. It's a close competitor to AV-30, at 1/10th the cost.
LPS Procyon is a hard coat product that protects very well, when sprayed on. I use this on engines that sit outside with excellent results.
Corrosion-X and ACF-50 are thin oils, incredibly effective at corrosion protection of welded seams. But best overcoated with a hard coat product.
Boeshield is a "middle of the road" product. It goes on very thin, but dries to a clear, sticky coating. It's semi durable. More durable than corrosion-x but less durable than AV-30 or Par-Al-Ketone.
http://www.chiefaircraft.com/aircraft/chemicals/corrosion-control.html
Good stuff! Thanks!
I like carwell because it is Krown and there is lots of history.
Hard dryign stuff has always scared me because it may not self heal as well and may let water sit underneath like a blister.
Have you ever seen these types of things?
I thought Krown was lanolin based, and rust check was mineral oil based?
not "oil base"
