I noticed some surface rust on the rear of the front wheel wheels and on the front of the rear wheel wells as well as along the frame rail under the car. Rather than attempt to match the paint/finish I decided to go with a spray on bedliner and masked off the areas to make it look like the plastic body cladding to protect the wheel wells on some vehicles. As a bonus, spraying the underside of the frame rails visually shrunk the visible side profile of the car.
I went through the proper steps (sanding, rust converter, sanding, primer, sanding, bedliner) so I wouldn't have to worry about the rust coming back.
Opinions on how it turned out?
front
rear
underside and frame rail
front
rear
